Old 02-22-2013, 02:15 AM   #1
Height from ground for Fresh Air Intake
I need to install a fresh air intake to the basement, and wondering what sort of clearance I should have from the ground. I've got a bit over 2 feet between ground level and the subfloor. I'm in Minnesota, so I ask because of the potential for snow to block the intake.
dvaupel is offline   Reply With Quote
Old 02-22-2013, 06:14 AM   #2
An old Tradesmen
12" above normal snow fall accumulation level.
Old 02-22-2013, 08:12 AM   #3
So do I then need to put a gooseneck in my line? To do 12" above snow level on a straight shot I would have to run it through one of the exterior walls of a bedroom....
Old 02-22-2013, 07:45 PM   #4
An old Tradesmen
Goose neck it.
Old 02-26-2013, 09:16 AM   #5
Forgot to ask this one earlier....what diameter of pipe do I need for this? It's a 105K boiler and a 30K water heater in an open 900 sqft basement. I'm actually puzzled by the need for the air supply, but the guy who's servicing our water heater (under warranty) won't do the work until after one is installed.
Old 02-26-2013, 07:24 PM   #6
An old Tradesmen
By code, 68 sq inches of cross section. 9" round. Many contactors just run a single 6".
Subpanel - equipment ground feed wire not terminated peaks Electrical 2 12-27-2012 05:37 PM
How does grounding work? scyarch Electrical 44 06-12-2012 05:59 PM
Fried electronics after earth ground accidentally disconnected oukachiru Electrical 7 07-12-2011 04:05 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 09:40 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
