-   -   Height clearance for ceiling hung furnace (http://www.diychatroom.com/f17/height-clearance-ceiling-hung-furnace-106973/)
acerunner 06-07-2011 07:00 PM
I want to hang a furnace horizontally in my garage ceiling. There is no space to stand it up vertically because it will prevent car from being able to pull in.
Is there a height clearance requirement to hang a furnace? I have 8' ceilings.
Aggie67 06-07-2011 08:56 PM
Why don't you just buy a horizontal unit. It comes with instructions.
Also, you're going to end up killing someone by hanging a vertical unit horizontally.
acerunner 06-07-2011 09:23 PM
you've misunderstood. I do have a horizontal furnace. more specifically, a multi-poise. What I would like to find out is if there is a minimum height above the ground that the furnace has to be at? for example, high enough for someone to walk under. There is no such data in the manual
Ron6519 06-07-2011 10:34 PM
Might be more of a building code question. Try the local building dept.
acerunner 06-07-2011 10:39 PM
thanks. That's what I figure. I was going to drop by the office when I get time. Until then, I wanted to see if there was any input here. I imagine the requirements, if any, would be similar in many counties.
Ron6519 06-07-2011 11:27 PM
I'm thinking the earthquake counties might be a bit more stringent.
