Heatpump Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 04-04-2011, 08:38 PM   #1
Heatpump problem
I recently had a leak in my evaporator coil. A professional service man replaced the evaporator and the next day the unit wouldn't work. I called him back and he said that the inside coil that he replaced had an orifice and the outside unit has an expansion valve. He had to reset a pressure switch outside to get the unit to work on AC. The problem was the inside unit needs an expansion valve which he will come back to install. He said to not use it on heat until he comes back to install the expansion valve. I suspect he used an coil inside for an AC unit not a heat pump. Can he actually fix the unit by replacing the orifice with an expansion valve. Is this acceptable, or is he trying to screw me?
jayel1 is offline   Reply With Quote
Old 04-04-2011, 08:48 PM   #2
An old Tradesmen
Rewards Points: 6,922
They don't really make a coil that is just for A/C for central units. Most likely something else is wrong. Since many systems have a piston inside an a TXV outside, and vice versa.
Old 04-04-2011, 08:51 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
hmmm should be ok with either....... maybe fan speeds are set wrong or plugged filter or wrong size orifice. I'm figuring he is resetting the high press switch.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
2 TVs fried: Electrical vs. Comcast Coax Cable Problem LynOprinka Electrical 17 07-16-2012 08:01 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 11:53 AM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 06:42 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
