Heatpump Failure - HVAC - DIY Chatroom Home Improvement Forum
Old 08-09-2009, 03:51 PM   #1
Angry
heatpump failure
I installed new goodman heat pump. It has been cooling fine for 6 weeks.Stopped cooling, fan running indoors and outside but compressor not running.Contacts OK.If I turn breaker off then wait a few minutes, turn it back on it will start cooling again.This has happened twice in two weeks.Would appreciate any help
winemaker is offline   Reply With Quote
Old 08-09-2009, 04:43 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Are you trained in HVAC?
Did you have someone who is help you?
What was the sub-cooling measurement?
Is this 22 or 410a?
If not I'd say to call a pro for a check out.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 08-10-2009, 11:27 AM   #3
A lot of heat pumps have a lock out feature should pressure go too high or too low. However this feature would likely shut down the entire condensor unit (vs the compressor only). The lockout gets reset by cycling power. You can usually read diagnostic codes on the defrost board.
This unit could also have a bad or marginal cap. Capacitor failures are common even on fairly new units.
Was this a DIY install? If not, then get the contractor out since a new unit should be under warranty.
hennyh is offline   Reply With Quote
Asphalt Shingle Failure WirelessG Roofing/Siding 11 03-30-2009 07:44 AM
HeatPump concerns walt1122 HVAC 11 03-02-2009 06:56 PM
Would to see these failure stats on Kilz Primers and Behr dcheek20 Painting 7 01-25-2008 05:56 PM
Paint failure at floor registers JOISTMAN Painting 7 05-01-2005 12:32 PM
