Heating Works Downstairs, Not Upstairs. - HVAC - DIY Chatroom Home Improvement Forum
Old 11-27-2013, 12:01 AM   #1
Heating works downstairs, not upstairs.
Hi!
Here is my situation: I have a Ruud gas furnace in the attic and a 2 zone house (upstairs/downstairs). I have two honeywell thermostats. The downstairs heat works fine. If I turn the set temperature up, warm air starts to blow out of the vents. Upstairs is a different story. When I turn the heat up, it sounds like the furnace turns on (for about 5-10 seconds), and air begins to blow out of the vent. The air, however, never gets hot. It stays pretty cool, and because of this the temperature slowly drops throughout the night. I have swapped the thermostats and still experience the same problem.
Any ideas?
andrewpthorp is offline   Reply With Quote
Old 11-27-2013, 05:53 AM   #2
An old Tradesmen
Rewards Points: 6,060
Problem is probably in/at the zone panel the stats are connected to.
Tags
furnace , gas , heat
need help upstairs tub/shower is leaking into downstairs kitchen travisdavis General DIY Discussions 1 11-19-2012 01:15 PM
Upstairs Cooling Problems enielsen HVAC 36 07-15-2011 09:39 PM
1886 Eastlake - add upstairs bathroom or expand downstairs bath?? TOTALN00B Plumbing 1 05-14-2011 10:54 PM
Only 1 of 2 Heating Zones Works KMPPROB HVAC 3 01-06-2008 02:13 PM
Help***Heat only works in part of the house Joe1629 HVAC 7 11-07-2007 08:10 PM
