Heating Vent Placement - HVAC - DIY Chatroom Home Improvement Forum
Old 02-01-2010, 06:28 PM   #1
heating vent placement
I am finishing my basement and don't know where to place the heat vents. Do I put them on the outside walls on the floor. And how many of them do i need? The room is about 15x25 and will have a fireplace. And second where should i put the cold air return. there is two vents and a return in the ceiling but i am guessing that is not the right place If anyone can help that would be great.
gaetz is offline   Reply With Quote
Old 02-01-2010, 07:37 PM   #2
Usually in a basement supplys are on the outside wall from the ceiling. Returns should be on inside walls and near the ground for the basement. How many depends on the number of windows, insulation, living area or mainly storage,how many exterior walls ect. Was it comfortable with 2 supplies and 1 return?
Old 02-01-2010, 08:28 PM   #3
An old Tradesmen
Rewards Points: 8,170
Supplies at outside wall area.
Avoid square or round supplies.
Use rectangular ones that throw the air down toward the floor. It will give you a better air mix.
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
How to update an old home heating vent heater Building & Construction 4 04-23-2009 06:20 AM
Removal of Forced Air Heating Vent eswickberg HVAC 1 02-26-2009 05:16 AM
Conduit Placement Next to Dryer Vent Mthrboard Electrical 1 05-10-2008 11:36 PM
