Old 09-30-2006, 11:29 PM   #1
Heating Retrofit in a Victorian Multi-Family House
I am looking for a suggested path to take regarding heating in a very large 6 family Victorian house North of Albany NY. It has old windows with storms and blown-in insulation. The house currently has 1 large antiquated Natural Gas boiler for radiators, probably some kind of conversion from coal or who knows what.
The efficiency rating must be scraping the bottom of the charts and the house has only 1 thermostat for all 6 units and common areas. I want to move towards dividing up the heat for each unit. For a separate house, I had installed direct vent Rinnai units. They are great but were expensive to purchase.
I’m not against investing some money to make this work but don’t know where to start. I don’t mind running the old system while I gradually install separate direct vent heating in each unit. I’m not even sure if that is practical or possible. And the truth is, I am already assuming that direct vent NG units are the way to go. Is there a better heating source for this type of application?
I am looking for suggestions regarding the approach and also brand names you have had success with, I may own this house for a while.
mumphis is offline   Reply With Quote
Old 09-30-2006, 11:36 PM   #2
World famous jerk.
Since your pipework already exists for the most part, why not install 6 low mass gas boilers in the basement and seperate the units apart by running radiant PEX to the necessary places to seperate the radiator pipework from unit to unit? That would be my first choice, since much of the work is already done, and it's just a matter of investigating how the current pipes are run to evaluate the strategic places to tie in to seperate the units.
mdshunk is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
How many heating vents needed per room? AllGoNoShow HVAC 4 01-23-2007 05:06 PM
