Heating Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 11-28-2011, 05:48 PM   #1
Heating problem
Anyone please advise me on what to do. I have a Goodman HVAC that is almost 4 years old. You can hear the thermostat click on when you turn it to heat and then a humming sound but the fan does not turn on. It will turn on if you switch it from auto to on. Steps I have taken.
1. Reset the thermostat and waited 5 mins
2. Turned main breakers to furnace off then back on.
3. Unplugged unit and plugged back in (It started to work for about 10 mins then tunred off)
atsudama is offline   Reply With Quote
Old 11-28-2011, 06:33 PM   #2
biggles's Avatar
if your cold set the stat to FAN/ON and set the heating to your desired temp...if the heating runs with the fan in on the relay on the control board might be shot or the motor winding for th eheating side...do you have an Induced Draft motor mounted above the burner and control board?
Old 11-28-2011, 08:00 PM   #3
I'm sure if I have an induced draft motor. When I took off the two panels on my left I had a circuit board with a fan behind the circuit board and on the right side I had a burner next to a blower. The heater is now working. Not sure why though. All I did was check wire connections and the fuse. I kept depressing the safety switch that the kills the power once the panels are off. The blower would work and I could hear clicking from the circuit board but the burner would not light and the fan would not come on. After messing with wires and safety switch evenutaly everything started working.
Old 11-28-2011, 08:05 PM   #4
Rewards Points: 582
it won't run for long sounds like may have a shorted wire or loose wire may want to find it so it don't ground out....cause more damage...
Old 11-29-2011, 12:35 PM   #5
jkv
Shut the power off and tighten them wires.
jkv is offline   Reply With Quote
Old 11-29-2011, 02:03 PM   #6
Sounds like your inducer motor is going bad......
harleyrider is offline   Reply With Quote
Laars mini-thermo ll zone heating problem ed lee HVAC 0 01-10-2011 04:06 PM
Lennox G50UH series heating problem katie2000 General DIY Discussions 2 01-08-2011 11:30 AM
Radiant floor heating questions secutanudu HVAC 35 03-08-2010 02:04 PM
Hydrokientix Heating System Not Heating damonl73 HVAC 11 12-18-2009 06:12 PM
Heating Problem brandonlynch Plumbing 3 01-11-2008 01:29 PM
