Old 02-03-2007, 03:07 PM   #1
Heating is in place. Cooling?
Moved into a one-story house, the gas-furnace is in the middle of the unfinished basement, all the duct-work is visible and accessible. The duct-work is not insulated.
If I wanted to install AC, would the easiest and cheapest way be to replace the gas-furnace with a furance that also does AC and insulate the ducts?
aljanney is offline   Reply With Quote
Old 02-03-2007, 04:06 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
For AC, all the HVAC contractor does, is install a A-Coil, and put the Condenser unit outside. Your Furnace should be okay, unless it is really old, and needs replaced. As for Insulating, it is up to you, if you have problems with condensation or not.
Slate Floor Electric Underfloor Heating Lottie Flooring 6 03-19-2011 02:50 PM
In-Floor Heating Cable Trouble... sootybuttercup Electrical 19 05-07-2010 09:39 AM
Trane XE80 Heating Question, Please help!!! Stephen1977 HVAC 3 01-30-2007 07:34 PM
How many heating vents needed per room? AllGoNoShow HVAC 4 01-23-2007 05:06 PM
kitchen floor/underfloor heating LanterDan Flooring 2 07-04-2006 08:17 PM
