Heating Pipes Knocking - HVAC - DIY Chatroom Home Improvement Forum
Old 02-12-2008, 09:18 AM   #1
Heating Pipes knocking
Hello
My Condo has a forced water heating system and when the heat is turned on, it osund like someone is hammering the pipes. what is the cause of this and how can I fix it?
kabuti is offline   Reply With Quote
Old 02-12-2008, 11:29 AM   #2
Look at the gauge on the unit and see what the PSI reading is.
You more than likely have air in the system.
redline is offline   Reply With Quote
Old 02-12-2008, 04:19 PM   #3
J Calvin Construction
jcalvin's Avatar
Rewards Points: 150
Water hammer. You can pick up something at the hardware store to fight it. I have never used them and can't recommend any one or if they even work. Talk to a plumber and they should know how to fix it.
jcalvin is offline   Reply With Quote
Old 02-12-2008, 06:22 PM   #4
It's not water hammer. Water hammer occurs when the pressure rapidly changes, as in a faucet or washing machine that is turned on then off. I too think there is air in the line somewhere. Does each unit have it's own boiler?
jerryh3 is offline   Reply With Quote
Old 02-12-2008, 06:48 PM   #5
thanks for the replies. yes, each unit has its own boiler. what is the normal operating pressure on a boiler? if it is air in the system how would i bleed it? i looked at all the baseboards and didn't see any bleed valves. Maybe someway to bleed the system at the boiler itself?
Old 02-12-2008, 08:00 PM   #6
My boiler usually runs around 18psi at max temp. Keep looking for a bleed valve. It may be on top of the boiler.
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 07:22 AM
Knocking Copper Hot Water Pipes in Winter desron1964 Plumbing 5 11-19-2009 10:24 AM
blockage in hot water heating pipes? gary in co HVAC 1 01-18-2008 03:36 PM
Installation of new pipes on Water main... NJE Plumbing 3 02-05-2007 12:06 PM
Trane XE80 Heating Question, Please help!!! Stephen1977 HVAC 3 01-30-2007 06:34 PM
