-   -   Heating outlets in suspended ceiling (http://www.diychatroom.com/f17/heating-outlets-suspended-ceiling-175381/)
macman44 03-24-2013 08:18 AM
I am finishing my basement (new house), and am looking for suggestions as to how to install the (supply) heating registers. Currently there are six standard 4x10 openings installed between the ceiling joists, obviously intended to be incorporated into a gyproc ceiling.
However, I plan to install a suspended ceiling some 6" below the joists, and am looking for the wherewithal to extend the 5" ducts supplying the current outlets to be flush with the new ceiling. So I have been looking for some kind of diffusers that will mount in the new ceiling grid, that I can connect to the 5" with flexible ductwork. Trouble is, I cannot find any such thing in any of the stores, nor were the associates in the stores able to give any useful suggestions. Yet I have seen 2' x 2' ceiling diffusers installed in offices, etc., although they could be expensive.
How do DIY-ers such as myself normally tackle this problem? What products do they use? Thanks for any suggestions.
yuri 03-24-2013 08:39 AM
google "ceiling diffuser" and hit images, there are hordes of em, also hit web and there are many online suppliers. check graingers
https://www.acklandsgrainger.com/AGI...m=cpc&utm_term
macman44 03-24-2013 09:58 AM
Thanks. I guess I had the wrong mindset in that I was looking for something that could mount directly to the ceiling grid. Most of those available seem to mount to a ceiling tile - although I was planning to use the flexible tiles for the ceiling, I can fit a small (e.g. 1' x 1') rigid tile to hold the diffuser, and that will work.
One more question. Is it OK to use the vinyl flexible 5" duct to make the connection between the existing metal 5" duct and the diffuser, or should I use the aluminum? The vinyl would be easier to work with, and will be easier to position the diffuser in the grid and not have it pulled out of place by the (not-very) flexible aluminum duct.
Thanks.
yuri 03-24-2013 10:50 AM
the vinyl will eventually dry out and crack and in theory is combustible and meant for cold air return only so I would not use it. if you are putting in a suspended ceiling it should not be that difficult as you can lift the next tile beside it and work with it that way. metal is better.
beenthere 03-24-2013 11:32 AM
2X2 lay ins. Common at HVAC supply houses.
