Heating A Large Reef Tank With Gas - HVAC - DIY Chatroom Home Improvement Forum
Old 04-06-2012, 06:26 AM   #1
Question
heating a large reef tank with gas
Is this a place I could get assistance heating 800+ gallons of water with gas? I'm considering a small tankless water heater connected to PEX. The PEX would coil in the sump as a heat exchanger. Maybe a Ranco controlling the pump. So all I have is a general idea. Is this workable?
Joe
salty joe is offline   Reply With Quote
Old 04-06-2012, 08:39 AM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
I don't think that would give you enough heat exchange. You may be able to do it with a titanium heat exchanger.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
The Following User Says Thank You to Clutchcargo For This Useful Post:
salty joe (04-06-2012)
Old 04-06-2012, 08:45 AM   #3
Rewards Points: 314
800 gallons.. hhhhmmmm why not a gas fired spa heater???? just a thought....
bobinphx is offline   Reply With Quote
Old 04-06-2012, 09:15 AM   #4
Experienced
Jackofall1's Avatar
Plastic is not a good conductor and wouldn't yeild very good results.
To what temperature are you trying to heat the water to?
Is the 800 gallon tank insulated?
Mark
Old 04-06-2012, 10:34 AM   #5
An old Tradesmen
Rewards Points: 7,816
Hpex would work fine.
Old 04-06-2012, 10:36 AM   #6
Experienced
Jackofall1's Avatar
Would it work, sure, would it work efficiently, no.
Old 04-06-2012, 11:17 AM   #7
An old Tradesmen
And why not?
Old 04-06-2012, 01:25 PM   #8
Mark
The water will be heated to the the mid to high 70s F. The tank is not insulated, but is in a heated area.
While PEX does not conduct heat nearly as well as metal, I plan to compensate by using 50'-100' coil of PEX. So in terms of efficiency, I can't see why using a long PEX coil would require any more gas than a short metal coil.
Old 04-06-2012, 04:21 PM   #9
Experienced
Jackofall1's Avatar
Heres the difference if you are interested
Polypropylene heat transfer = .06 Btu/ft2/hour/DegF differential
Copper Heat transfer = 232 BTu/ft2/Hr/DegF differential.
So you will wait a real long time to heat it, and while waiting you lose efficiency keeping an 80% efficient heater running for so very much longer to achieve the same task.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
Old 04-06-2012, 04:21 PM   #10
Experienced
Jackofall1's Avatar
And why not?
Read post #9
Mark
Old 04-06-2012, 04:52 PM   #11
Mark
Wow and Wow! That would be a lot of heat up the chimney. I had no idea the difference was so great. Then let's say a short titanium coil heat exchanger.
How would the water in the system be topped off? Would some sort of sight glass to monitor water level be good?
Old 04-06-2012, 06:03 PM   #12
An old Tradesmen
Mark
Cite your source. Copper doesn't transfer 232 BTUs per sq ft per degree F difference.
I think you'll find you BTU is low for pex piping also.
The Following User Says Thank You to beenthere For This Useful Post:
Old 04-06-2012, 06:12 PM   #13
An old Tradesmen
A 4" copper pipe only loses 111 BTUs per linear foot per hour, at a 40F temp difference. A 4" copper pipe 1 foot long, is 150.72 sq inches of copper, which is just over 1 sq ft.
The temp difference would have to be 99F to have a 241 BTU an hour per sq ft heat transfer.
Old 04-06-2012, 09:30 PM   #14
Experienced
Jackofall1's Avatar
I didn't pull this from a dark piece of anatomy----
http://www.engineeringtoolbox.com/th...als-d_858.html
Pex is suited for water distribution due to its insulation qualities this is why they use it, that and its resistance to corrosion when used as in slab radiant heat, copper doesn't do well corrosion wise encapsulated in concrete.
If they were anywhere remotely the same conductivity wise, you could use Pex for wiring, would love to see that, after all conductivity of both heat and electrical energy are similar when talking about materials.
Old 04-06-2012, 10:16 PM   #15
Thanks for that link Jackofall. Titanium is the only metal I would consider using. It has a (Btu/(hr oF ft)) of 11-13 at 68 F, according to that link. Way, way lower than copper. Plus titanium is quite pricey. If PEX is 0.06 (Btu/(hr oF ft)), it would take 200' of PEX to transfer the heat of 1' of titanium of the same diameter. Which is hard to believe-but what do I know.
Doesn't PEX used in heating applications have aluminum under the plastic to improve heat transfer?
What is a good efficient heating system for cold climates? reveriereptile HVAC 7 02-08-2012 08:26 PM
Filling a 20lb propane cylinder off a 1000 gallon tank--anybody done it? jbeall Building & Construction 26 12-27-2011 11:30 PM
hot water tank question? guest Plumbing 5 12-13-2011 09:24 PM
Oil furnace / tank questions... pure_energy1 HVAC 26 06-22-2009 08:47 PM
Changing a heating element in an electric tank brokenhammer Plumbing 6 04-15-2009 07:42 AM
