Heating Gone Bad - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-30-2006, 04:12 PM   #16
the water level was not low at the time of inspection....i was present at the time....heating tech said there was lot of corrosion inside the water level cutoff system.....said it probably was not flushed for a long time.he gave that the reason for the failure ...low water level would have turned the system off....in this case the cutoff sytem didnt disable the system...
Originally Posted by redline View Post
$5500 is not extremely high for the size of unit. If you live in a higher cost of living area then it would be a fair price. You must remember that the prior system lasted for over 25 years. I just wish I could buy a new car for $5500 and have it last 25 years ?
The price may also reflect the fact that it is winter time and the heating company is in high demand.
The boiler along may cost upwards of $2,000 before they even start to remove the old unit.
Side note - It may be wise to add more insulation in the attic.
The inspector should have found this if the water level was low.
christy123 is offline   Reply With Quote
Old 12-30-2006, 06:02 PM   #17
I have never seen a home warnty company cover much.That is sad.I bet if you read the fine print on the home inspectors report it will say something like "no guarntys on inspection only a opinion". Most times home inspecters are not even liscensed in the fields they inspect.
trollmastergeneral is offline   Reply With Quote
Old 01-02-2007, 09:06 AM   #18
The newer unit should be more efficient then the 25 year unit thereby saving you money each year. The pay back period may be less than 7 or 8 years for the $4,000 price. ($5,500 - $1500 insurance)
redline is offline   Reply With Quote
Old 01-02-2007, 09:14 PM   #19
Do you guys have any recommendations for a good quality Gas bolier for steam heat?
Old 01-02-2007, 09:19 PM   #20
Thoroughbred Mopar Man
Rewards Points: 502
Hi christy123
My favorite boiler is a Dunkirk. But a Burnham boiler is probably the top of the class in reliability and ability. You should be able to research either of these on line. The only one that I have used recently that I did not like at all was a Crown. It has had problems almost every year since we put it in. Hope this help to educate you, happy hunting.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
Old 01-02-2007, 10:16 PM   #21
thanks carrierman...will probably go with burnham
Old 01-04-2007, 07:48 PM   #22
The current boilers only demise was the failed(clog) water valve and not boiler itself.
Old 01-14-2007, 03:33 PM   #23
I am giving changing to water heating sstem a serious thought. can you guys recommend a good water heating boiler.
Old 01-14-2007, 04:25 PM   #24
Rewards Points: 502
Hi christy123
Burnham again is the best on the market. But my favorite in the residential setting is the Dunkirk. The Dunkirk is one of the quietest boilers I have ever seen. The Q90 and Q95 are unserpassed by anyone I believe in efficiency. Here is the Dunkirk website, check them out for your self, www.dunkirk.com. You just want to stay away from the foreign made like Munchkin etc. The Dunkirk and the Burnham are both American made and backed. Hope this helps with your decision.
Good luck
Rusty
Old 01-14-2007, 04:57 PM   #25
747
registered
747's Avatar
Rewards Points: 534
My hotwater boiler is a weil mclain. Its 43 years old and still going strong. All that has been done to it is this. Two years ago i had my plumber replace the circulator pump it was original. He said he could have just replaced the bearings. I said slap a new circulator pump on it. I also have replaced one white rogers zone a flow valve on it. There are two its two zoned. That is it besides cleaning it once a year. Finally i think that is a fair price for a new steam boiler at 5500. Steam is excellent heat also hotwater is. I think those blow away forced air. See steam and hotwater is more expensive upfront but they last forever. You would never get 25 years out of a forced air furnance or in my case 43 years and still going strong.
ps oh i forgot had to put a new expansion tank on it.
747 is offline   Reply With Quote
Old 01-27-2007, 12:21 PM   #26
Has the system been changed ?
Old 02-08-2007, 10:51 PM   #27
Where are you located, what City?
How's it going, with the house? Did you get a new boiler?
I also have and old house, Never ending work,
Is it a one family? I am in NY...You?
Woodpecker is offline   Reply With Quote
In-Floor Heating Cable Trouble... sootybuttercup Electrical 24 12-18-2014 08:01 PM
Slate Floor Electric Underfloor Heating Lottie Flooring 6 03-19-2011 01:50 PM
Trane XE80 Heating Question, Please help!!! Stephen1977 HVAC 3 01-30-2007 06:34 PM
How many heating vents needed per room? AllGoNoShow HVAC 4 01-23-2007 04:06 PM
kitchen floor/underfloor heating LanterDan Flooring 2 07-04-2006 07:17 PM
