Heating Garage Shop - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-17-2011, 11:52 AM   #31
Hvac Pro
yuri's Avatar
Rewards Points: 386
yep. but it needs to be sized properly. sounds like a LOT of trouble to go thru IMO. sawdust is NEVER good to get into any furnace and depending on the wood, moisture, temp etc you can get spontaneous combustion and fires. even with an electric heater you ALWAYS want to blow it out. KISS is my motto, keep it simple st*pid. electric heaters suit that bill nicely. I like the propane torpedo idea to get the temp up and then maintain it with the electric heaters. Suits the KISS philosophy too.
Old 12-18-2011, 05:17 AM   #32
jkv
Andrew, I have a 30x40 shop, I do HVAV and build cabinets lots of saw dust. I insulated my shop and run a torpeto heater 50,000 in it I have no problems at all and it maintains the temp. just fine, all my joints set just fine. I agree with Yuri if you try to put in gas or electric furnace you are asking for more problems and you will find that you spend more time with your furnace then with the woodworking
jkv is offline   Reply With Quote
Old 12-18-2011, 06:01 AM   #33
An old Tradesmen
Rewards Points: 8,170
Originally Posted by secutanudu View Post
Thoughts on my "furnace in a closet" idea? is it doable?
Doable, yes. Practical, not really. It would eat up a fair amount of space, and at 300 sq ft, you don't have a lot to spare.
Old 12-18-2011, 06:51 AM   #34
Just call me Andrew
Rewards Points: 1,020
Thanks, guys. I think I'll just go with a couple of electric baseboards as recommended, and just keep them cleaned out before or after each use. Thanks!
Andrew
secutanudu is offline   Reply With Quote
Garage floor Tomperro Building & Construction 3 07-17-2011 11:37 PM
garage heating sjnewton Building & Construction 9 02-22-2010 09:58 AM
heating a room over the garage moisheh HVAC 1 02-10-2010 06:42 AM
Finished garage to home office/work shop gone_fishing Project Showcase 8 07-11-2009 03:21 PM
heating garage farrington135 HVAC 2 12-05-2006 02:15 PM
