Heating Garage Shop - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-15-2011, 10:37 AM   #16
Rewards Points: 268
They should be safe around sawdust. You dont get a blister just touching them. When its below 15* or so outside they take a long time to get the temp up but I have no insulation. Once it gets warm, they maintain well. Not very expensive to buy either.
JackDidley is offline   Reply With Quote
Old 12-15-2011, 10:39 AM   #17
Just call me Andrew
Rewards Points: 1,020
Not a bad thought, they are cheap. How big is your garage? Mine is about 300 sq. feet with a ~11' peak in teh ceiling. No drywall or ceiling material at all.
I have no insulation either. I have no drywall either. Can I put one of these baseboards (or 2, or 3) right up against the wood studs or do I need some sort of fireblock?
Maybe I can hang a forced air electric heater (the ones that get glowing hot) to use to get up from 10* to 50* before going in there, then swap to the basboards to maintain it.
Andrew
secutanudu is offline   Reply With Quote
Old 12-15-2011, 10:43 AM   #18
Rewards Points: 268
I dont have drywall either. Just screwed into studs. Also you can add more sections as needed.
Old 12-15-2011, 10:43 AM   #19
Just call me Andrew
Nice. I edited my post just as you typed your response. How big is your garage?
Andrew
Old 12-15-2011, 10:44 AM   #20
Just call me Andrew
Duh, you already told me. Much bigger than mine.
Andrew
Old 12-15-2011, 10:47 AM   #21
Rewards Points: 268
I have a propane torpedo that I used a couple times when it was like 5* out. Run it 20 minutes or so, then let the electric maintain.
Old 12-15-2011, 03:11 PM   #22
Just call me Andrew
Do you need a dedicated circuit for each section of baseboard?
Andrew
Old 12-15-2011, 03:19 PM   #23
Rewards Points: 268
No, they are tied together and on one breaker.
Old 12-15-2011, 09:18 PM   #24
Just call me Andrew
I found someone who is selling one of the modine "hot dawg" 45k btu units fairly cheap. It's a propane unit.
Questions:
1. Can I convert it to Nat. Gas? How? Expensive?
2. If I go propane, how big of a tank would I need? I have never used propane heat before. Do I need to get a giant tank in my yard? Or can I go with something small like I'd use for the bbq (probably a ridiculously naive question, i know!)
Andrew
Old 12-15-2011, 10:29 PM   #25
Rewards Points: 268
That may need to be a new thread.
Old 12-15-2011, 10:30 PM   #26
Just call me Andrew
I was thinking the same thing....
Andrew
Old 12-16-2011, 12:46 AM   #27
Questions:
Answers;
1. Yes, you can convert from propane to natural gas as the maker, Modine, sells models that run on both. It'll just be a kit of smaller sized orifices that need to replace the currently installed propane ones. It's pretty common these days for the maker to ship orifices for both propane and ng along with the unit. If the seller does not have the ng orifices then it shouldn't cost more than $20 to get them from the manufacturer I'd think
2. A bbq tank or 2 should suffice, unless you want to enter a contract to fill up your 100 lb pound tank, or lug it your self to get it filled.
VIPlumber is offline   Reply With Quote
Old 12-16-2011, 07:34 AM   #28
Just call me Andrew
Hmm, so maybe I can buy it as-is, and use a bbq tank. Convert to gas next year to distribute the cost.
Can I hook up the propane myself, or is that something best left to a contractor? Do I need to leave the tank outside?
Andrew
Old 12-16-2011, 12:05 PM   #29
Just call me Andrew
Turns out the one that guy was selling wasn't the sealed combustion style, oh well.
If I buy a used old inefficient gas furnace, can I build a small closet in the corner of the garage and put an intake vent into that closet (from outside), run the duct into the garage?
Would that give me heat as well as keep the sawdust away from the burner?
Andrew
Old 12-17-2011, 10:23 AM   #30
Just call me Andrew
Thoughts on my "furnace in a closet" idea? is it doable?
Andrew
Garage floor Tomperro Building & Construction 3 07-18-2011 12:37 AM
garage heating sjnewton Building & Construction 9 02-22-2010 10:58 AM
heating a room over the garage moisheh HVAC 1 02-10-2010 07:42 AM
Finished garage to home office/work shop gone_fishing Project Showcase 8 07-11-2009 04:21 PM
heating garage farrington135 HVAC 2 12-05-2006 03:15 PM
