Heating Garage Shop - HVAC - DIY Chatroom Home Improvement Forum
Old 11-14-2011, 03:12 PM   #1
Just call me Andrew
Rewards Points: 1,020
Heating garage shop
I am in the process of insulating my garage. It has open framing with no drywall. There is an enclosed breezeway between my garage and the house. There is no roofing
I plan to put r13 on the walls, something more on the underside of the roof (with the foam proper vents). The roof is peaked in the center of the garage, all open.
I am running a 60A subpanel to the garage this week, should have plenty of power.
What things do I need to consider when heating this garage?
Electric the way to go? Baseboards? Do I need fireproofing of any kind? Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 11-14-2011, 04:48 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,112
Depends on what you plan to do in there or store. If you are using solvents or doing autobody or dusty work including carpentry you may want a sealed combustion gas unit heater. If not a basic 240 volt 4800 watt yellow/orange utility heater from HDepot is your best bet. Cheap and simple and nothing to go wrong with it. They are also handy if the heat goes off in your house. Just rig up a clothes dryer 3 prong outlet adaptor to the one that comes with it as they are different.
Old 11-14-2011, 04:50 PM   #3
Just call me Andrew
I'll be doing woodworking, so sawdust is an issue. I am definitely not looking to spend too much money....
Andrew
Old 11-14-2011, 04:52 PM   #4
Hvac Pro
yuri's Avatar
As long as you take your air compressor and blow it out at the end of every shift it should be OK.
Old 11-14-2011, 04:54 PM   #5
Just call me Andrew
I don't have an air compressor yet...
Andrew
Old 11-14-2011, 04:59 PM   #6
Hvac Pro
yuri's Avatar
Then Mama and the kids can use some hints for what to get you for Xmas. Cut out pics from the brochures at HDepot and drop them in strategic places so you don't get the cheap no name stuff. Nothing worse than getting an el cheapo $30 rechargeable drill when you wanted the nice $120 Makita.
Old 11-14-2011, 05:42 PM   #7
Cheapest method to get around 4800 watts is to use three 120V $15 space heaters. Sometimes you can get them for $10. Hang/mount them from the ceiling/walls so you can't trip over them.
Don't expect 4800 watts to heat up your garage from 20 degrees to 60 degrees very quickly, though. Will take all day.
If you need that you need some big BTU's (60K) from a gas heater.
http://www.littlegreenhouse.com/acce...-compare.shtml
Portable gas heaters are around $400, harder to install, but will operate at 1/3 the cost.
bungalow_steve is offline   Reply With Quote
Old 11-14-2011, 06:08 PM   #8
Just call me Andrew
hehe, need to get married, have kids, and convert to Christianity first
Andrew
Old 11-14-2011, 06:34 PM   #9
Hvac Pro
yuri's Avatar
Or win a reasonable sized lottery prize. I probably have $10-20,000 in tools in my garage and another $10,000 in my service van. Oy.
Old 12-12-2011, 06:42 PM   #10
Just call me Andrew
So I think I am finally going to do this, as the subpanel install is almost done....now that it's getting cold. Is it safe to hang space heaters from the ceiling?
Is it a bad idea to use a gas-burning heating equipment in the vicinity of sawdust? What about an electric heater? I don't really plan to do spraying of any chemicals in there. Mostly woodworking.
Andrew
Old 12-12-2011, 07:42 PM   #11
Just call me Andrew
I should mention that the garage is about 14' x 30x and has open framing with a peaked roof, the center of the garage being about 12' high down to about 7' on the ends.
Would one of these do the job? I also have a small oil-filled electric radiator I could use.
http://www.air-n-water.com/product/G73.html
Andrew
Old 12-13-2011, 02:34 PM   #12
Just call me Andrew
Any ideas?
Andrew
Old 12-14-2011, 12:11 AM   #13
I've had my eye on one of these for a while, http://www.leevalley.com/en/wood/page.aspx?p=44590&cat=1,43456,43465,44590.
VIPlumber is offline   Reply With Quote
Old 12-14-2011, 12:52 AM   #14
Rewards Points: 268
Baseboard heat works great in my garage. No fumes. No flames. No noise. 21 x 21 garage. I think I put 10 feet on two opposing walls.
JackDidley is offline   Reply With Quote
Old 12-15-2011, 10:16 AM   #15
Just call me Andrew
How hot do they get? They safe around sawdust?
What about suspending them from the ceiling?
Andrew
Garage floor Tomperro Building & Construction 3 07-18-2011 12:37 AM
garage heating sjnewton Building & Construction 9 02-22-2010 10:58 AM
heating a room over the garage moisheh HVAC 1 02-10-2010 07:42 AM
Finished garage to home office/work shop gone_fishing Project Showcase 8 07-11-2009 04:21 PM
heating garage farrington135 HVAC 2 12-05-2006 03:15 PM
