Heating Ducts - HVAC - DIY Chatroom Home Improvement Forum
Old 02-19-2009, 10:03 AM   #1
heating ducts
After reading some articles, I have discovered why my small bedroom (15x10) is so cold, when the rest of the house is comfortable. The supply is not only against an interior wall and not against the exterior wall by the window 15 feet away, but is directly under the cold air return. As obvious as this is now, it didn't occur to me when purchasing the home from the builder in August. I think I can access the supply from the garage and run a new supply to the exterior wall by the window. Is this something I can do myself?
Retirement is offline   Reply With Quote
Old 02-19-2009, 11:38 AM   #2
Rewards Points: 150
Without more details and knowledge of your abilities no one could really say.
Is this a new house? If so do you have any recourse against the builder? Or is it something the inspector should have caught?
Gary
Gary_602z is offline   Reply With Quote
Old 02-19-2009, 12:19 PM   #3
Remodeling Contractor
if you have access you should be able to relocate this with no problems.
Old 02-19-2009, 12:33 PM   #4
Not a prob as long as there are no fixtures in the way.
Put the new register under the window. Register should be a 10x6 or 10x8.
hvaclover is offline   Reply With Quote
Old 02-19-2009, 02:48 PM   #5
Heating ducts
Thanks for the replys. Good point about the building inspector, who was let go in October...go figure. Gonna try to cut in this weekend.
Old 02-19-2009, 04:14 PM   #6
Well - you'll probably cut your hands at least 37 times. Not sure if that count's as "no problems" or not.
Sheetmetal is tough on your hands.
Garasaki is offline   Reply With Quote
Old 02-19-2009, 04:24 PM   #7
There is always flex duct.
re-sizing heating ducts david belletsky HVAC 1 10-04-2007 06:12 PM
Rehab Mess- Ducts Knocking-Furnace Vibrating drmark7 HVAC 7 03-18-2007 04:34 PM
Soffits for Heating ducts handyflyer Remodeling 5 02-06-2007 05:07 PM
How far should insulation be from heating ducts... AllGoNoShow Remodeling 4 11-09-2006 05:47 PM
