Heating Duct Work In Attic Or Crawl Space? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-02-2013, 05:59 AM   #1
Juyaya's Avatar
Question
Heating duct work in attic or crawl space?
Hi Everyone,
Please help me determine where we should put our new heating duct work. Our house is a single story house (1400 sf) built in the 1950's. We are located about 30 min south of San Francisco. The house currently have no AC, only gas furnace for heating during winter. The attic gets pretty hot during the summer. The crawl space is neither insulated nor sealed, only a layer of plastic sheet on the soil preventing moisture from seeping up. The crawl space also have very low clearance, about 12" to 16". The living room and kitchen will have new vaulted ceiling which eliminates the attic above.
The contractor recommended duct-work in the crawl space under living room/kitchen, while in the attic above bedroom/bathroom. Not sure if that's the best way since I understand "hot air rises; cold air falls". But the attic is also warmer than the crawl space in the winter, so that might mean greater energy efficiency for a heating system.
What is your take on the location of heating duct work?
Juyaya is offline   Reply With Quote
Old 10-02-2013, 07:34 AM   #2
PoleCat's Avatar
Rewards Points: 1,646
The crawlspace will have less extremes in temperature but 12 to 16" is too tight of a space to work in.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
Juyaya (10-02-2013)
Old 10-02-2013, 10:00 AM   #3
raylo32's Avatar
Rewards Points: 1,286
My house has vaulted ceilings upstairs and insulated flex ducts that branch off to registers in the ceilings of each room from a plenum in the accessible central part of the attic. Works fine here in MD. Maybe another option for you....
Live long and prosper.
raylo32 is offline   Reply With Quote
The Following User Says Thank You to raylo32 For This Useful Post:
Juyaya (10-02-2013)
Old 10-02-2013, 10:51 AM   #4
HVAC Tech/Owner
Rewards Points: 604
Sounds more like a job to figure out WHERE we can put it as apposed to the most energy efficient place.
Technow is offline   Reply With Quote
The Following User Says Thank You to Technow For This Useful Post:
Juyaya (10-02-2013)
Crawl space insulation question gregsenne Insulation 11 01-16-2013 03:26 PM
Crawl Space Insulation in NWT Canada too-cold Insulation 3 11-10-2012 02:11 PM
Cold Climate Duct Work rhysup HVAC 10 04-12-2012 06:55 AM
Open crawl space to heated basement benjamincall HVAC 1 03-04-2011 07:52 PM
Insulating 18" duct in crawl space astroboy HVAC 0 10-29-2010 06:53 PM
