Heating Duct Noise - HVAC - DIY Chatroom Home Improvement Forum
Old 02-19-2014, 12:24 PM   #1
Rewards Points: 986
Heating duct noise
I bought a 7 year old house last summer. When winter came and the heat turned on, the ducts to my bedroom got very noisy. They were quiet with the A/C on.
I found the large rectangular ducts (obviously I don't know much about HVAC) were made of two pieces of metal, crimped on the two edges where they joined. The crimping was not real tight and they were free to move. I figured the heat for some reason made them move. I put sheet steel screws into the crimps on the ducts going to my bedroom and about 80% of the noise went away. I had to do the entire system to get the remaining 20%.
So my question...
Is this normal or did I get a substandard install? It seems to be a reputable company (on buying the house I found they had vented the furnace wrong. They came back, after 6 years, and replaced all the venting; probably would have cost a couple thousand to hire it done. That's pretty reputable, no?) I can't imagine anyone living with these noises (though my wife isn't sure what I was complaining about) nor can I imagine too many people doing what I did to fix it.
Just trying to make sense of it.
Toller is offline   Reply With Quote
Old 02-19-2014, 01:05 PM   #2
An old Tradesmen
Rewards Points: 7,816
Its a Pittsburgh seam. May have loosened up over time, and from high static pressure in heat mode.
humming/vibration coming from heating pump lakawak Plumbing 1 01-28-2014 06:49 AM
Is this fiberglass insulation safe (touching heating duct)? nutlog Insulation 6 01-27-2012 07:18 PM
Heating Duct Layout rahimab HVAC 1 01-15-2012 05:01 PM
Heating Duct Ticking Noise mmohanna Building & Construction 6 01-10-2010 12:52 PM
teleposts thru heating duct suks2beme General DIY Discussions 4 01-08-2010 09:54 AM
