Heating Duct --- How Hot Is Too Hot? (pic) - HVAC - DIY Chatroom Home Improvement Forum
Old 12-02-2009, 07:53 AM   #1
Question
Heating duct --- how hot is too hot? (pic)
Unfortunately, I didn't give too much thought at the time but we didn't reroute a 2nd floor heating vent. It's right behind the toilet.....no biggie, the upstairs is mostly unused. I'll plan better next time.
But the house has oil heat with a serious furnace. Last night walked upstairs while it was on and the area around the vent was really hot....below, above, around the vent. Behind the tile is green 1/2 drywall.
Should I be concerned about any affects on the drywall because of the heat? (or surrounding areas)
HautingLu is offline   Reply With Quote
Old 12-02-2009, 05:54 PM   #2
For starters I'd worry a bit about drying out rubber gromets on the tank to bowl connection and then the wax ring at the base of the toilet leaking. Maybe not an issue but certainly a concern.
Move the duct up above the tank and no problems. Or at the very least look for a duct shut-off going to that register from the basement.
Shamus
Shamus is offline   Reply With Quote
Old 12-02-2009, 07:06 PM   #3
First thing I did when I got home. There was a single duct that seems to run upstairs to that bath.
Hopefully I'll do better with the next bath
Plywood heating duct ? willem HVAC 10 09-29-2010 08:09 PM
Capping un-needed heating duct? paredown HVAC 0 07-02-2009 07:26 PM
running gas line near or under heating duct NowItsShowtime Plumbing 1 03-26-2009 02:18 PM
Oh no...I dropped a piece of MDF into my heating duct. J187 Building & Construction 6 03-25-2009 08:58 AM
Is it alright for insulation to touch a heating duct? vetting Building & Construction 5 02-28-2009 03:46 PM
