Heating At Cottage - HVAC - DIY Chatroom Home Improvement Forum
Old 09-28-2012, 06:26 PM   #1
Heating at cottage
Hi guys
I just bought a cottage that has two propane fireplaces and electric baseboards in bedrooms, however in the utility room, in the picture attached, the only source of heat is the back of the propane fireplace, I'm wondering if that is enough to keep that room warm enough during the winter, considering the well and pumps are there and I don't want the pipes to freeze
indep is offline   Reply With Quote
Old 09-28-2012, 07:08 PM   #2
biggles's Avatar
how hot does that backing get,maybe adding a fan to pull air if it was enclosed
Old 09-28-2012, 09:31 PM   #3
Rewards Points: 12,840
I'm not there to see it in person, but that sure looks like one messed up vent for that fireplace.
If you that concered with the pipes freezing a simple $20.00 pump house heater could act as a back up if that pipe does not keep it above 32 deg.
Old 09-28-2012, 09:35 PM   #4
Missouri Bound's Avatar
Two things I would do. #1. Get a professional out there to fix that flue situation ASAP. #2. Get a small electric heater for freeze protection....another baseboard heater would be fine.
Do you want it your way or the right way?
Old 09-28-2012, 09:46 PM   #5
that pipe around the main vent is just insulation, nothing more, the actual vent goes all the way out of the attic, that extra piece around is insulation foam wrapped around it
Old 09-28-2012, 09:56 PM   #6
Sure looks like a clearance issue to the wall from that flue pipe to me.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
Missouri Bound (09-28-2012), oh'mike (09-28-2012)
Old 09-28-2012, 10:08 PM   #7
DIY staff
Rewards Points: 7,174
Also look like a mighty big flue for a small gas heater---to big is bad---not enough heat to carry the gasses up and out.
Old 09-29-2012, 09:32 AM   #8
biggles's Avatar
removing all that insulation wrap around the flue riser will heat the room also
What is a good efficient heating system for cold climates? reveriereptile HVAC 7 02-08-2012 09:26 PM
Electric baseboard heating virago Electrical 8 05-18-2011 12:36 PM
Radiant floor heating questions secutanudu HVAC 35 03-08-2010 02:04 PM
Hydrokientix Heating System Not Heating damonl73 HVAC 11 12-18-2009 06:12 PM
Electrical consumption of baseboard heater CowboyAndy Electrical 7 03-24-2008 08:27 PM
