Old 09-01-2009, 09:17 PM   #1
Heating & Cooling for Attic addition.
We are in the process of converting our attic into 2 additional rooms. The area is about 750sq ft.
We are trying to look at some options for heating and cooling the attic. Our existing furnace/ac cannot accomidate the additional space. We have received prices for ductless systems, but we live in Massachusetts, and the winters can get very cold, so we would need to supplement the ductless system with electric baseboard and the few quotes we got were surprisingly high.
What are some of our options in adding an additional furnace and ductwork in the attic? I was told that the ductwork, running a gas line and adding a furnace in the attic is very expensive. Are there any other options?
ddave23 is offline   Reply With Quote
Old 09-01-2009, 09:42 PM   #2
Hvac Pro
There is no easy or cheap way to add heating and A/C. If your electricity rates are bearable I would use electric baseboard heaters. They are 99.9% foolproof, comfortable, quiet, require very little maintenance or repairs unlike a furnace. You save $$ on repairs, in the long run this offsets the extra cost of the energy they use. A/C can be done with window units (shakers) or ductless minisplits. Minisplits are quite expensive to install initially as they are Japanese imports . There are also some very nice modern portable A/C units which vent thru a window and are very quiet and popular.
More On This Topic
Newer, more energy efficient homes have been constructed to seal out the outdoor environment almost 100 percent. This condition allows loaded, stale air to accumulate unless windows are opened. Open windows allow some of the heating or air conditioning... Read More »
To present a topic on budgeting. Again with the help of Expert Village, I hopefully will be able to help people and assist people in terms of developing a budget. The biggest components of a budget again, as I indicated are your housing, food and shelter... Read More »
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. Something else you want to think about if you do decide to finish your basement in stages, is access to the plumbing and heating. If you decide to finish... Read More »
If you've had trouble insulating your home from hot summer weather, you might consider investing in an attic fan. While air conditioning can help to cool air in the livable portions of your home, most attics do not have air conditioning. After hours of... Read More »
Heating and Cooling brotherjohndavi HVAC 0 06-24-2009 04:29 AM
Heating and Cooling unit pauls HVAC 3 12-09-2008 09:49 AM
Heating And Cooling Sunroom crane doc HVAC 2 11-26-2008 01:51 AM
new heating cooling system agrace HVAC 4 07-25-2008 08:26 AM
Heating is in place. Cooling? aljanney HVAC 1 02-03-2007 04:06 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
