Old 10-04-2010, 04:46 PM   #1
Heating a basement
I am considering walling off an area in my unheated basement of my summer cottage where all the plumbing is. This area measures approx. 20 feet by 6 feet and 8 feet high. The purpose is to protect my pipes from freezing and also would extend the use of my cottage throughout the winter. I am thinking an electrical heat source. What would I need to heat such an area to maintain a 50 degree temp.? The use of heat tapes makes me uneasy.
Roland899 is offline   Reply With Quote
Old 10-04-2010, 05:32 PM   #2
An old Tradesmen
Heating a basement
About 1500 watts.
Old 10-04-2010, 05:41 PM   #3
steveel's Avatar
Heating a basement
Figuring the need for heat has a lot to do with the location's climate, and how you construct/insulate the new heated space.
Also, if you are worried about pipes freezing, then what is your plan for an extended power outtage during a time when you can not go there to keep an eye on things? My folks simply drain their plumbing between winter cabin visits. I'm not sure what they do for the hot water heater, traps, or toilet.
steveel is offline   Reply With Quote
Old 10-04-2010, 08:22 PM   #4
Heating a basement
You would need to drain the water heater and also flush all toilets with the water shut off and put antifreeze in toilets and traps.
Most of the plumbing, hot and cold, will be drained when you open all faucets and drain the water heater.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
AllanJ is online now   Reply With Quote
Options for Cold Basement Concrete Floor? jefferis Flooring 16 12-09-2009 01:23 PM
Basement mhughrob Remodeling 1 07-11-2008 08:11 PM
Radiant Floor heating in Basement? mfleming HVAC 3 06-10-2008 09:22 AM
Tankless Heater for DHW and basement heating clemkonan HVAC 8 09-24-2007 12:43 PM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
