-   -   Heating/ AC unit (http://www.diychatroom.com/f17/heating-ac-unit-31898/)
flatfootedduck 11-15-2008 07:47 AM
Heating/ AC unit
Over the summer my A/C unit went down. The compressor will come on for about 15-20 seconds and shut back off. I tried trouble shooting it myself checking switches, relays, fuses, and wires, but could not find the problem. I call a local repair company and was told I had a bad compressor. Because the repair was going to be costly I decided to wait. Now that cooler weather is here we are running the heater and I have noticed the furnace is doing the same thing. Could this still be do to a bad compressor?
HvacWiz 11-15-2008 11:09 AM
Do you have a heat pump ?
biggles 11-15-2008 11:21 AM
if it is a heat pump the compressor runs the same in cooling/heating mode.the 3-way valve is the stat call for what air handler sees in temperatures.if it is a gas fired furnace there is no connection between them only the 24Vs and the stat
flatfootedduck 11-16-2008 01:23 PM
Thanks for the replies, i have tried other boards and got nothing you guys are great.
it is not a heat pump. the therm is about 4 years old and is one of those programmable ones. i think i will try to replace the the therm and see if anything changes.
