Heating/AC Requirements? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-04-2008, 07:08 PM   #1
Rewards Points: 152
Hello All,
What are the requirements of heating and AC if a new addition was to be built?
Can the heating and AC from the existing structure be used to heat the addition or does there need to be a heat source or duct into the new addition.
I am planning to put a Ductless heat pump out in the new addition but it is pretty comfortable without it (the main house is heating it just fine).
I am not sure how they will take to this when final inspections come.
THanks!
sandyman720 is offline   Reply With Quote
Old 03-04-2008, 07:37 PM   #2
hvac/refrigeration
Yes it can be pulled from the existing system. As long as the existing system can handle it. I do not know where you live. The heat is normally not an issue, cooling is usually your problem. I would advise you have a Hvac contractor to look at it for sizing requirements. Just out of curosity what size is the addition?
metal-maniac is offline   Reply With Quote
What are the joist requirements for a tile floor? slatergrl Flooring 8 07-16-2008 11:08 AM
Deck Requirements? sandyman720 Building & Construction 5 01-08-2008 08:27 PM
Drain clean out requirements steve1234 Plumbing 2 11-21-2007 12:06 AM
What are the requirements I must do to get electricians license Kraze Electrical 16 08-28-2007 09:00 PM
Requirements for Sill anchors and ledger boards? sandyman720 Building & Construction 7 08-20-2007 07:56 AM
