-   -   Heating/AC Requirements? (http://www.diychatroom.com/f17/heating-ac-requirements-18021/)
sandyman720 03-04-2008 06:08 PM
Hello All,
What are the requirements of heating and AC if a new addition was to be built?
Can the heating and AC from the existing structure be used to heat the addition or does there need to be a heat source or duct into the new addition.
I am planning to put a Ductless heat pump out in the new addition but it is pretty comfortable without it (the main house is heating it just fine).
I am not sure how they will take to this when final inspections come.
THanks!
metal-maniac 03-04-2008 06:37 PM
Yes it can be pulled from the existing system. As long as the existing system can handle it. I do not know where you live. The heat is normally not an issue, cooling is usually your problem. I would advise you have a Hvac contractor to look at it for sizing requirements. Just out of curosity what size is the addition?
