Heating A 700 Sq. Ft. House. - HVAC - DIY Chatroom Home Improvement Forum
Old 08-24-2010, 06:37 PM   #1
Heating a 700 sq. ft. house.
Hi. I'm looking for advice on heating a tiny 2 room house (700 sq) efficiently. I live in the midwest near KC, Mo. The house currently has a fa furnace, 25 yrs old. I"m told may not last the winter. Everything is old, the duct work is shot (flexy) and I'm thinking about putting up a propane wall unit heater and setting a propane tank. For a.c. I'm thinking about a portable unit and doing away with all the forced air stuff. The nat. gas Co. charges me a ton each month and I hate it. I'm trying to cut costs in any way I can. Am I on the right track? Thanks, Tatie Anne
tatieanne is offline   Reply With Quote
Old 08-24-2010, 06:44 PM   #2
My last house was 912 sq ft
I installed a 24,000 BTU wall unit that cooled the entire house
Cathedral entrance, cathedral kitchen, partial flat poorly insulated roof
I even installed a 10,000 BTU unit in the bedroom - cathedral ceiling
If I turned them both on high I could ice skate
I heated mostly with wood
My grandparents had a wall propane unit that worked great
...and that was years ago
Not sure how big the area was
Old 08-24-2010, 07:31 PM   #3
Rewards Points: 150
isn't propane more expensive than natural gas???
what about a pellet stove. My buddy has one and loves it. I guess there's even a machine that will make pellets out of any organic material... your leaves, grass clippings, food, paper, etc... talk about living off the grid! I have a small wood stove (buck 21) that i burn wood that I collect over the summer, good way to supplement for free
johnnyboy is offline   Reply With Quote
Old 08-24-2010, 07:35 PM   #4
An old Tradesmen
Rewards Points: 7,796
Propane is generally more expensive then natural gas.
A pellet stove may be your best bet.
I'd use a window unit, before a portable A/C.
Old 08-25-2010, 02:57 PM   #5
Rewards Points: 150
Assuming this is your property, I would start off by looking into the insulation in the walls, under the floors,in the ceiling. Is this a wood /siding or concrete block/brick outside? basement or a crawl space? Concentrate on a well insulated home, by talking to some pros. Let us know what the walls have inside. The better the insulation, the lower the fuel bill.
bernieb is offline   Reply With Quote
Old 08-25-2010, 03:21 PM   #6
Rewards Points: 292
Just curious: If you make pellets out of (compressed) leaves, isn't it the same as burning leaves, which is prohibited in my area?
Also, how do you make pellets, grind up material, add binder, compress, dry?
veesubotee is offline   Reply With Quote
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Old coal furnace......worth saving? [PICS] HautingLu HVAC 16 06-24-2010 12:36 PM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 04:47 PM
Heating Unit in the Attic Bad Idea? Part of House on Slab cloves HVAC 3 08-18-2009 11:37 AM
Hello. I moved my house... shtoink Introductions 10 06-25-2008 01:40 PM
