Heating - HVAC - DIY Chatroom Home Improvement Forum
Old 01-25-2014, 06:33 AM   #1
heating
I had a new a/c and heating unit installed in my home in may .I had to turn on heater since it had gotten cold, the unit is constantly turning on and off .I have had outragous entergy bills the last two months ,I have sealed all doors and windowand have checked every where no leaks .I am baffled why the unit is running so much and the house is still chilly can anyone help .Its a 3.5 ton unit in a 1600 sf house they put all new duct work can that be the problem ?I have checked for leaks in the attic can see nothing visiable .
susan g is offline   Reply With Quote
Old 01-25-2014, 07:23 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,626
Ayuh,.... Considerin' it's been record Cold the last couple months, I'd blame it on Mother Nature,...
Old 01-25-2014, 07:36 AM   #3
Rewards Points: 163
Or it could be the same as mine, grossly oversized. We were down to -15 a week or so back and my 80K 92% was cycling on and off. If it was sized right it should have been running almost continuously. Predicting almost -20F Monday night and I'll bet it will be cycling again.
Anyone know a good way to determine the correct size for a replacement furnace based on data? I've been trending my supply and return temps, the outdoor air temps and furnace fan status for a while now. I'll be getting a new one pretty soon and would like to get it sized correctly. Not based on a rule of thumb, and then doubled for safety!
But anyway, what type of heat do you have?
52Caddy is offline   Reply With Quote
Old 01-25-2014, 07:58 AM   #4
heating
My home is all electric .I have long runs on some of the duct work that was installed
Old 01-25-2014, 08:01 AM   #5
chitownken's Avatar
Rewards Points: 510
Have someone come out and do a Manual J load calculation. Or you can go to one of the online sites and hope that you filled it out correctly.
chitownken is offline   Reply With Quote
Old 01-25-2014, 09:06 AM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 116
If there is a leak on the return duct it may be sucking in cold air from the attic. May have to look closer or get the installer to do so.
Old 01-25-2014, 09:20 AM   #7
Rewards Points: 236
is there a register close to the thermostat ?
Fix'n it is offline   Reply With Quote
Old 01-25-2014, 09:34 AM   #8
Where might i find j load calculation
Old 01-25-2014, 10:27 AM   #9
Hvac Pro
yuri's Avatar
Rewards Points: 116
here...
http://www.hvaccomputer.com/gtarget1...Fe4-MgodPF4AoQ
Old 01-25-2014, 12:29 PM   #10
May be as simple as setting up the proper blower speed- or could be oversized. Regardless you should contact the installation company to have them look at it before you run into even worse problems resulting from what you are experiencing right now. I would think it would be covered under parts and labor warranty if it was installed in may. Even if there is nothing wrong and it is due to the extra cold we have had this year (however doubtful) I would think it would be worth the service call charge for piece of mind
Gene S. is offline   Reply With Quote
Old 01-25-2014, 12:31 PM   #11
Keep in mind you personally trying to adjust anything or having someone other than the installer work on it could and probably would void any labor warranty. Call the installer!
Old 01-25-2014, 02:30 PM   #12
An old Tradesmen
Rewards Points: 7,808
Do you ever set the thermostat back, and then turn it up later, or use programmed set backs. if so, stop doing that. it causes the aux heat to come on whether needed or not.
What is a good efficient heating system for cold climates? reveriereptile HVAC 7 02-08-2012 08:26 PM
Mini Split for heating in cold climate landev HVAC 9 01-29-2012 10:18 AM
Radiant floor heating questions secutanudu HVAC 35 03-08-2010 01:04 PM
Hydrokientix Heating System Not Heating damonl73 HVAC 11 12-18-2009 05:12 PM
Electrical consumption of baseboard heater CowboyAndy Electrical 7 03-24-2008 07:27 PM
