Old 08-18-2011, 04:53 PM   #1
heating
Can you use yellow flex line from the black pipe to the heater
oceandweler is offline   Reply With Quote
Old 08-18-2011, 07:08 PM   #2
heating
Best to call the local heating inspector and ask. It's allowed in some locations,not at all in others. If allowed follow the instructions on grounding and termination outside the furnace cabinet exactly.
Marty S. is online now   Reply With Quote
Old 08-19-2011, 12:58 PM   #3
REP
heating
Are you talking about an appliance connector or to flexible SS gas line?
You must be carefull in choosing the right size of "yellow" gas line.If not sure use 3/4 inch instead of 1/2 inch..
I have always used nipples and Tees and caps and unions and gas shut off on the heater and then the flex line.
Other wise when you work on heater you have to shut off the gas to the whole house to work on it.
REP is offline   Reply With Quote
Any "baseboard' heating that installs on wall? Piedmont Plumbing 2 01-21-2011 06:05 PM
Radiant floor heating questions secutanudu HVAC 35 03-08-2010 02:04 PM
Hydrokientix Heating System Not Heating damonl73 HVAC 11 12-18-2009 06:12 PM
Electrical consumption of baseboard heater CowboyAndy Electrical 7 03-24-2008 08:27 PM
Central Heating Frustration SassySue General Discussion 4 11-29-2007 07:46 AM
