Heatilator NDV4236il Fireplace - HVAC - DIY Chatroom Home Improvement Forum
Old 12-07-2012, 12:42 AM   #1
Rewards Points: 141
Our new house came with a Heatilator NDV4236il Pro Pane Fireplace and just had the gas installed and the gasman showed me how to operate it with a remote ,
It came with 2 bags one witch looks like black coal and a small bag of sand? How do I add this ? Does some one have a pic on how these are added below the logs? This is my first time.
bote110 is offline   Reply With Quote
Old 12-07-2012, 05:00 AM   #2
An old Tradesmen
Rewards Points: 6,544
Page 56.
http://www.firesidecorner.com/downlo...s/4055_187.PDF
Old 12-07-2012, 07:28 AM   #3
Rewards Points: 141
Yes pg.56
I guess I place the charcoal on the pan below the wood , an then sprinkle the Vermiculite on top.
It says (refer to Figure 15.4). But it jumps from Figure 15.3 to Figure 15.5 there was no pic of it?
Old 12-07-2012, 04:17 PM   #4
An old Tradesmen
There may be other install manuals online that have the pic. I don't work on those things, so i can't tell you how they are placed, other then what those instructions said.
Old 12-07-2012, 04:55 PM   #5
Rewards Points: 141
Well I hope I did it right , I place the Rock Wool on the pan {not to cover the holes} then I added the lava rock and sprinkle the Vermiculite on top. It look blueish in the in the front and yellow flames in the middle. To me it still did not look right will play with it when I move in.
Old 12-14-2012, 12:33 AM   #6
Rewards Points: 141
This fireplace has blower that kicks on when it reaches a cretin temp , I hear it come on but really can not fell any air flow blowing out? Could this be broken? should I fell and hot air get blown out if it's working right?
Old 12-14-2012, 05:43 AM   #7
An old Tradesmen
I would think so. But it may be a slow air movement that you don't feel it far away.
How to go about replacing fireplace surround? NewHomeDIYGuy Remodeling 9 01-26-2012 10:56 PM
Need opinions on tearing out old fireplace Dwillems Building & Construction 9 09-06-2011 12:37 PM
Fireplace construction question scottyv81 General DIY Discussions 1 01-29-2011 10:26 AM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 11:07 PM
