Heatilator ND4236i - Main Will Not Light - HVAC - DIY Chatroom Home Improvement Forum
Old 08-15-2010, 10:57 AM   #1
Heatilator ND4236i - main will not light
Hello,
I have a Heatilator gas fireplace model # ND4236i. Recently, my home sustained a pretty good surge during a thunder storm. It destroyed the compressor on my central air conditioner, new computer, damaged my fireplace and a few other things. While inspecting my fireplace I noticed that the intellifire ignition system control module (#593-592) showed physical signs of being burnt. I was unable to get a volt reading from any terminal on the module except from the power supply leads. So, I replaced the module and crossed my fingers in hope that this was the only thing that got damaged. After the replacement of the control module the pilot will light but the main burner will not. The ground wire is securely attached. I can not see any noticeable damage to any of the wires and I tested them all with an ohm meter. The pilot does not continue to spark after the pilot flame has been lit and I tried resetting all of the wired to no avail. It seems like the valve is bad (#750-500) as there is only a 2mvdc reading at main burner once the pilot lights but if I disconnect the main burners lead from the valve and check it - there is 3.8vdc there. I would appreciate any direction someone can offer.
flew-d-coop is offline   Reply With Quote
Old 09-01-2010, 07:10 AM   #2
Coil too the main gas valve fried also. Has to be replaced.
lamon2524 is offline   Reply With Quote
Old 09-20-2010, 03:24 PM   #3
Is the coil something that can be replaced separately or is it integrated into the valve? If it can be replaced separately, do you have a part number as there does not appear to be a listing for a coil in the service manual (page 75 below).
http://www.heatilator.com/downloads/...s/4031-550.pdf
Old 09-20-2010, 05:07 PM   #4
HVAC / Plumbing
probably comes as a single unit. Call the manufacture
kenmac is offline   Reply With Quote
Old 12-13-2010, 06:34 PM   #5
Heatilator
I am interested in knowing how you like the Novus 4236. I am thinking about getting one...three actually. Anybody know where I can see a video of one of these?
Jonr is offline   Reply With Quote
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 05:28 PM
Dual Main Breakers dcwestcott Electrical 3 02-23-2009 08:26 PM
Need to replace can light with standard light Woodcutter Electrical 3 02-29-2008 08:06 AM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 09:18 PM
