Heater Won't Light - HVAC - DIY Chatroom Home Improvement Forum
Old 10-29-2011, 12:46 PM   #1
heater won't light
I have a york diamond 80 that will not ignite. I have replaced the igniter and checked all roll out switches. only getting 12 volts from board to igniter is problem with board/
njbrad is offline   Reply With Quote
Old 10-29-2011, 12:51 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
does the board display a flash code?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-29-2011, 12:54 PM   #3
on initial start com light (green) comes on then red status light flashes once and stays solid after attempt at starting
Old 10-29-2011, 01:03 PM   #4
AKA HVACTECHFW
what model board is that? Is there a legend that says anything about the led flash codes? Most likely located on the blower door (check both sides)
IT IS WHAT IT IS
Old 10-29-2011, 01:13 PM   #5
board has been replaced not sure of model at this time and currently not in front of heater
new light to existing switched light sirsparksalot Electrical 4 04-22-2011 04:23 PM
Basic light wiring question speedster1 Electrical 3 11-29-2010 07:48 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
Trouble with gas water heater pilot light Hotlantadave Plumbing 1 07-10-2009 10:38 PM
Water Heater Pilot Light dankreboot Plumbing 3 09-03-2008 08:46 PM
