Heater Venting Question - HVAC - DIY Chatroom Home Improvement Forum
Old 08-07-2010, 07:01 PM   #1
Heater venting question
I'm installing a dayton propane heater in an a frame cottage. The installation instructions require the exhaust pipe to rise above the roof peak. Heater is located near an outside wall (the lowest point of the A frame). If I were to run the pipe straight up, it would have to stick up 20 ft in the air. Pipe is metal 4 inch double walled metal exhaust pipe. Is it safe to run the exhaust pipe diagonally through open space - strapped to the diagonal a-frame ceiling, but not touching it, then penetrate the roof near the ridge?
This would require two 45 degree turns.
huai is offline   Reply With Quote
Old 08-07-2010, 07:43 PM   #2
An old Tradesmen
Rewards Points: 7,338
As long as you have 1/4" per foot slope upward it is.
Old 08-09-2010, 02:13 PM   #3
How many inches does double wall (Type B) chimney flue have to clear from combustible materials (studs, sheetrock) when venting a gas heater?
Old 08-09-2010, 03:42 PM   #4
An old Tradesmen
Generally 1 ". Varies with application.
Also need a thimble when penetrating walls.
Venting med. efficiency furnace and H2O heater thru wall? cbrc5eric Building & Construction 2 04-02-2010 11:07 PM
Venting Water Heater near Central Air Unit rchrivera Plumbing 5 03-16-2010 11:03 PM
Heater wiring and breaker size question Tmb9862 Electrical 12 12-26-2009 03:27 PM
Rasing rafter ties and Venting Question. Does AtlanticWBConst. Still Frequent? gregt848 Building & Construction 11 09-24-2009 08:46 PM
Venting question. Bcoleman6 Plumbing 7 03-21-2008 03:41 PM
