-   -   Heater venting question (http://www.diychatroom.com/f17/heater-venting-question-78179/)
huai 08-07-2010 08:01 PM
I'm installing a dayton propane heater in an a frame cottage. The installation instructions require the exhaust pipe to rise above the roof peak. Heater is located near an outside wall (the lowest point of the A frame). If I were to run the pipe straight up, it would have to stick up 20 ft in the air. Pipe is metal 4 inch double walled metal exhaust pipe. Is it safe to run the exhaust pipe diagonally through open space - strapped to the diagonal a-frame ceiling, but not touching it, then penetrate the roof near the ridge?
This would require two 45 degree turns.
beenthere 08-07-2010 08:43 PM
As long as you have 1/4" per foot slope upward it is.
huai 08-09-2010 03:13 PM
How many inches does double wall (Type B) chimney flue have to clear from combustible materials (studs, sheetrock) when venting a gas heater?
beenthere 08-09-2010 04:42 PM
Generally 1 ". Varies with application.
Also need a thimble when penetrating walls.
