Heater Return Duct - Moved To HVAC Forum - HVAC - DIY Chatroom Home Improvement Forum
Old 05-16-2007, 12:38 AM   #1
Heater Return duct - Moved to HVAC forum
I am in the process of design work for a home remodel. As part of the remodel the gas central heating unit will be moved to a new location.
Should the heater return duct draw return air near floor level or near the cieling level?
Thanks for you help.
John
backpacker2 is offline   Reply With Quote
Old 05-16-2007, 11:30 AM   #2
I am just a home owner...not a HVAC pro. Sharing the setup in our home with gas heating (built in 1987) on our first floor we have two returns at floor level located kinda at opposite corners of the first floor in two different rooms (living room and family room). There is a third return that is located upstairs at ceiling height at the top of the stairs near where we can look down into the family room.
Both the family room and the living room have vaulted ceilings. The stairway to upstairs is opened on the living room side. There is a large opening with railing that looks down into the family room.
I can only guess the physics regarding the location of the three returns is possibly to recirculate the cooler lower air on the first floor with the much warmer air at the top of the second floor...to uniform the air temperature throughout the house.
Casey
caseywa is offline   Reply With Quote
Do I need a HVAC return vent in basement? westing HVAC 13 04-03-2014 01:43 AM
Contractor + gas heater duct rms Building & Construction 7 07-24-2007 08:24 PM
Central Air return duct location backpacker2 HVAC 3 05-28-2007 10:07 AM
Hot Water Holding Tanks - Moved to Plumbing Forum Boatnuts Plumbing 1 04-19-2007 06:44 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
