Heater Register Vent In Bathroom Moving Up - HVAC - DIY Chatroom Home Improvement Forum
Old 09-15-2012, 01:23 AM   #1
Rewards Points: 200
Question
Heater register vent in bathroom moving up
Dear all thanks for reading this thread...
Now that we were able to remove soldered cap on my bathroom shower flange and recover the shower feature in this bath (see the other thread), our next step is to handle that heater register vent (see photo below):
I guess we have two options here:
  1. Move the current heat register vent UP to close to the ceiling (so that shower water won't go into the vent)
  2. Complete "block" the vent and then put up tiles to cover it up (yes we were able to find idential tiles)
I would like to hear your opinions about which option would make better sense to you. Apparently, if we move up the vent, this bath will still be able to enjoy heat during winter (which is a big plus)... however, I don't know if there will still be any possibility or concern that water might still permeate through the vent and whether that would damage the furnace. On the other hand, if we are to block the current vent and re-tile it, that seems to be a safer option but then we will lose heat in this bath. Thoughts or comments? How would you handle such a case (especially from HVAC perspective)?? Many thanks!
ohman is offline   Reply With Quote
Old 09-15-2012, 06:48 AM   #2
Can you turn the furnace blower/fan on and confirm that this vent works?
Can you pull back and take more pictures of the other walls?
What is below your bathroom? A finished living space or an un-finished basement?
allthumbsdiy is offline   Reply With Quote
Old 09-15-2012, 07:34 AM   #3
An old Tradesmen
Rewards Points: 6,112
Unless you have a really really good bathroom fan, remove that supply and cover up the hole. The water vapor from taking a shower will go into it and condense, causing mold down the road.
Power Vent Water Heater Replacing Draft Vent polebarn HVAC 13 03-28-2012 07:12 PM
Do I need a power vent water heater? bw77 HVAC 1 06-20-2011 06:05 PM
gas water heater vent into furnace vent??? Master Brian HVAC 2 05-08-2011 01:16 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 11:50 PM
can I 'patch in' a bathroom vent into my kitchen's stove hood vent? joeyboy HVAC 2 09-10-2007 01:36 PM
