Heater Power Venting - HVAC - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 06:49 AM   #1
Ckg
I have a tjenlund power venter that vents my house heater out the side of my house.The vent cap is on the side of my house is about 8 feet high.My problem is whenever there is a strong Southeast wind (which is often in the winter here) my heater short cycles due to the wind blocking the vent and tripping the pressure switch. My only way to fix this is to move the vent lower to the ground which entails blocking a basement window with wood and mounting the vent cap there...about 2 feet of the ground which is ok by code...this way I could cut the wind with shrubbery or whatever...I guess my question is ...is it ok to do this ?
Ckg is offline   Reply With Quote
Old 11-29-2010, 05:52 PM   #2
An old Tradesmen
Rewards Points: 7,802
The power venter will require a clearance between it and the wood. other then that, its ok.
Venting med. efficiency furnace and H2O heater thru wall? cbrc5eric Building & Construction 2 04-02-2010 11:07 PM
Tankless water heater venting problem kchopper Plumbing 1 08-17-2009 03:32 PM
Power vented water heater noise mainstreetprod Plumbing 1 02-06-2009 10:26 PM
Amp meter Results - SE Cable Bad or Power CO jamiedolan Electrical 30 01-23-2009 12:16 AM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
