Heater Not Turning On - HVAC - DIY Chatroom Home Improvement Forum
Old 12-09-2011, 08:54 PM   #1
Heater not turning on
When I set the thermostat to heat, it doesn't turn on. I hear a click on the thermostat, but nothing happens. It says on the thermostat display that it is set to heat and we have tried turning up the temperature to 80, but still nothing. We called a repair guy, but they won't come out until Monday. Any ideas on what I can check? I don't know much about my system, but if anybody has any questions I'll do my best to answer them if it will help. Thanks.
BTW, it wasn't working when it started getting cold then last week my wife was messing with the thermostat and it came on. She doesn't remember what she did, but it hasn't turned on since we turned it off that day.
lreyes12 is offline   Reply With Quote
Old 12-09-2011, 09:05 PM   #2
Rewards Points: 582
get us a picture of furnace with doors off......you said wife was messing with thermostat and unit came on....are you handy enough to perform some test on unit.... get a picture of thermostat too..
Old 12-09-2011, 09:27 PM   #3
I don't have any pics of the unit, but I'll try to get some tomorrow. Here is the thermostat. Sorry about the quality.
What kind of tests?
Old 12-09-2011, 09:32 PM   #4
I'm Your Huckleberry
Rewards Points: 2,270
Look for flash code on control board in furnace.
Doc Holliday is offline   Reply With Quote
Old 12-09-2011, 09:38 PM   #5
Stat only knows its calling. Furnace knows problem.
Old 12-09-2011, 09:58 PM   #6
Is it on the roof or in the attic?
Old 12-10-2011, 12:02 AM   #7
Is what on the roof or in the attic? We can only help you as much as you help yourself.
Old 12-10-2011, 01:12 AM   #8
Sorry, I was in the wrong topic. I'll take a look at the control panel in the morning.
Old 12-11-2011, 02:47 PM   #9
Not sure what I'm looking at, but that is with the panel taken off.
Old 12-11-2011, 04:09 PM   #10
how
Rewards Points: 1,104
You can take the thermostat off its base and pigtail a wire to the Rh and W on the base to bypass the thermostat as the possible problem.
(MY wife often "touches" things she'd like to see replaced)
Is the breaker or an external on/off switch for the furnace "on"?
The picture you sent shows a roll out switch on the left side of the burners which has a reset button. This may restart your furnace but indicates other problems that will need to be addressed.
Do you see a flashing led light on the control that looks like it has a spark plug wire attached to it.
These would be things to first start checking out and report back about.
how is offline   Reply With Quote
Old 12-11-2011, 11:18 PM   #11
I don't see an LED light. Here is a better pic of the burners. ( I think these are the burners)
Old 12-12-2011, 01:42 AM   #12
I connected the Rh and W wires and the heat came on. So I have a bad thermostat?
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Central heater works only when I help jump start the motor by turning it. stanlam HVAC 10 12-11-2012 05:24 PM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
Turning off electric water heater when not in use? skipjack Green Home Improvement 10 03-08-2011 09:02 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
