Heater Metal Cover Rust Treatment - HVAC - DIY Chatroom Home Improvement Forum
Old 12-13-2011, 01:32 AM   #1
Rewards Points: 200
Question
Heater metal cover rust treatment
Dear all,
Thanks for reading this thread. My brother-in-law who is living in a condo has central heating in his master bedroom (the condo building was built in 70's). However, the cover is showing its age and has a lot of rust on it. Is there any way that we could clean out the rust and make it look better? As the unit is heated and can get really hot, so I don't know if some of the chemical treatment when used on this type of metal surface would create some health concern or not. Thoughts or comments about this?
Here are some photos of the metal cover of the heating unit:
ohman is offline   Reply With Quote
Old 12-13-2011, 06:30 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,636
Ayuh,... Those don't get That hot,...
Sand it, 'n paint it whatever color you'd like...
Even latex wall paint will work on those things...
Bondo is online now   Reply With Quote
Old 12-13-2011, 12:15 PM   #3
Rewards Points: 200
Bondo, thanks for your reply!!
BY the way for this kind of surface (metal) what type of grade/grit should I use? Thanks again!!
Old 12-13-2011, 03:19 PM   #4
Bondo's Avatar
Ayuh,... The last 1s I did, I sanded with 180 or 220, 'n painted with rustoleum industrial enamel...
You could use rusty metal primer, 'n top coat from rattelcans if ya want...
'course, you'd have to take 'em apart, or tape 'em up....
Solar "Batch" Hot Water Heater, Help Please Ralph III Green Home Improvement 1 10-29-2011 09:12 PM
REZNOR gas shop heater WHOOMP ! on ignition Wildcat355 HVAC 14 01-29-2010 05:57 PM
Metal cover with T in front yard tripower General DIY Discussions 6 06-19-2009 03:09 PM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 02:53 AM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 07:34 PM
