Heater Kit - HVAC - DIY Chatroom Home Improvement Forum
Old 12-01-2010, 09:00 PM   #1
heater kit
i have a 4 element 2o kv heat kit and istalled it in a old ac unit it is three phase with 2 60 amp breakers and a 9 pin plug i have no board or plug to plug into how do i hard wire it to get heater to run correct i need the 24 v i have a white brown and blue off the heat kit where do they go please help its cold its a goodman a36-00 handler
geneo224 is offline   Reply With Quote
Old 12-01-2010, 09:03 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
you need a schematic for the plug to know how to wire it
hvactech126 is offline   Reply With Quote
Old 12-01-2010, 10:41 PM   #3
i have one but it doesnt show thermostat wires coming in
Old 12-02-2010, 03:19 AM   #4
An old Tradesmen
Rewards Points: 8,168
Hmmm. Its not actually 3 phase.
A 3 phase 20KW heat package at 208 volt service would only need a single 3 pole breaker of 70 amps(a single 3 pole at 240 volts).
The heat kit for that Goodman is still made, and so is the control board for it. Don't install a heat kit in it if you don't have the control board. As some of the safeties must go through the board also.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
Min distance from baseboard hotwater heater capslock General DIY Discussions 2 05-25-2010 07:31 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
