Heater Issue - HVAC - DIY Chatroom Home Improvement Forum
Old 12-02-2009, 06:40 PM   #1
Heater Issue
I was hoping I could get some advice on a heater issue I am having.
The issues is that when I turn my thermostat to warm and move the temperature up the system light comes on but no heat blows out. The oddity here is that if I leave it on heat it will begin to blow randomly. Sometimes it will happen the same day and sometimes it will be 3 days later. Also, I can get the air conditioner to work plus get the fan to blow. The heater is a Trane as is the Thermostat and they both came with the house. I am unsure what model the heater is but the Thermostat is a XT302B.
I am completely ignorant in the ways of HVAC so any advice or ideas would be great and very very much appreciated.
Thank you,
Dan.
D_R_Paulsen is offline   Reply With Quote
Old 12-02-2009, 06:57 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,240
We really need a model # from the furnace and air conditioner or heat pump. Remove the front door of the furnace and look inside. Should be a sticker on the outdoor unit. Is it a heatpump?.
Old 12-02-2009, 07:06 PM   #3
An old Tradesmen
Rewards Points: 7,318
Yeah. Afraid no way to know if you have a heat pump, and electric furnace, or a gas or oil furnace. From your brief description.
Old 12-02-2009, 08:39 PM   #4
I was able to find what kind of heater it is and the model number as well.
It is a trane XL1200 and the Model Number is YCY030FLM099.
Maybe that will help.
Thanks for the rapid response though.
Tankless Water Heater Issue fjacky Plumbing 12 01-21-2011 06:28 AM
Electrical issue - 240V - Water Heater emoore Electrical 9 09-30-2009 01:45 PM
Rheem water heater gas valve issue tsherv Plumbing 4 05-26-2009 09:38 AM
