Heater Fresh Air Intake Question - HVAC - DIY Chatroom Home Improvement Forum
Old 10-13-2012, 11:33 PM   #1
Heater fresh air intake question
My dad's house has an old Rheem gas heater & I don't have a photo right now but it looks like this illustration & here is my question:
Is the fresh air intake the only area where air should get in? So that way all that air going in to the system gets filtered?
The access panel is not loose but is not air-sealed & lets the air leak in a little bit. Should we make it completely air-sealed?
thanks
Tim142 is offline   Reply With Quote
Old 10-14-2012, 08:24 AM   #2
Yes to both questions. BTW that's called return air. Fresh air is a pipe from the return to outside.
Old 10-14-2012, 07:39 PM   #3
biggles's Avatar
if the return is in an unconditioned space it wil pull colder air into that duct "around the filter slot" and mix with the returning conditioned space air and basically add a longer run time on the stat..$$$
Old 10-15-2012, 12:34 PM   #4
Thanks for the replies.
Here is a photo. The heater is in a closet inside the house. There is an opening where cold air comes in that closet from the crawl space.
I sealed the bottom tray & everything around the air filter opening. So now air should only get in to the fan through the filter.
Old 10-15-2012, 08:06 PM   #5
Rewards Points: 582
fixing the air return is one thing...that gas connector is not legal..its not allowed to run inside the furnace like that...and it should be stainless and not old brass....sorry ben sr
Fresh Air Intake for new boiler? nperkins HVAC 15 09-15-2014 06:02 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
Garage heater venting question brill0724 HVAC 1 12-09-2009 08:06 PM
Water Heater Question DIYNewbi Plumbing 8 05-30-2009 03:41 PM
Fresh air intake damper - Open or Closed? dtran HVAC 7 01-06-2009 06:30 AM
