Heater Fan Wont Shut Off!!! :( - HVAC - DIY Chatroom Home Improvement Forum
Old 12-25-2007, 11:10 PM   #1
Heater Fan wont shut off!!! :(
Look here on this post on a diffrent forum explains my problem so i don't have to waste time typing it out again.
http://forum.doityourself.com/showthread.php?t=328801
If anyone has any helpful info on this please do not hesitate to help! thanks!
UpsideDwnCircle is offline   Reply With Quote
Old 12-26-2007, 01:51 AM   #2
HvacWiz's Avatar
Rewards Points: 252
sounds like the sequencer that controls the fan and electric heating elements are sticking causing your unit to not shut down. simple fix
HvacWiz is offline   Reply With Quote
Old 12-26-2007, 03:58 AM   #3
Are you talking about the unit outside or the thing i took a pic of under the crawlspace O_o? Ahh!!!! where is this sequencer located?
If its such a simple fix tell me how to do it!! please!! thanks!
Because the unit outside works fine ( at least i think so ) but the big thing in the crawlspace under the house is what wont shut off even with the outside a/c unit off. ;_;
Sorry im not an expert at terms of hvac components obviously, im just a mear resident of this house. Otherwise if i was an expert i wouldnt be here asking these questions now would I?
Old 12-26-2007, 11:50 AM   #4
Union HVAC Tech.
Do you have a heat pump or a furnace?
bigMikeB is offline   Reply With Quote
Old 12-26-2007, 03:16 PM   #5
A Heat Pump.
Old 12-26-2007, 03:32 PM   #6
Union HVAC Tech.
Are you sure the fan switch on the subbase isn't in the "on" position?
Old 12-26-2007, 05:53 PM   #7
You mean the thermostat? No its always set to "AUTO" never since we lived here has it been set to "ON".
and if your talking about the "g" wire no its not touching anything as of now and it the utilites fan would still run.
Old 12-26-2007, 06:27 PM   #8
HvacWiz's Avatar
Rewards Points: 252
Yes the air handler in your crawlspace is where your seqencer is located. I know you would like to save a few bucks and that is why you are on here, but may i recomend that you call a pro if you are not sure what you are doing, could save yourself alot of hassle that way.
Old 12-26-2007, 09:43 PM   #9
I probably will just call someone to come out to fix or the least get a free estimate, because I'd rather not electrocute myself for being stupid and not shutting something off the right way and poking around in something high voltage like that.
Ah the one thing i hate about some service calls is some companys do charge like 50 bucks just to come to your house and say "yup its broken, and its gonna cost ya $3,000 to fix it." I usually faint when i hear that part.
But seriously it shouldn't cost much right? I live in Raleigh, NC.
I'm gonna go do a search for a company that offers free estimates before they do any work online right now. I may post back again. If i don't then the problem has probably been fixed.
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
Installing a tankless water heater ? bdalekid Plumbing 3 02-26-2007 07:26 PM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 09:40 PM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 04:01 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
