Heater Damper Slam? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-17-2009, 09:30 AM   #1
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
Heater damper slam?
I have a Dayton gas heater and after a heating cycle there is a loud slam like a damper shutting. It's a bit creepy when it happens in the middle of the night!
How do I fix this?
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Old 12-17-2009, 02:04 PM   #2
If it is a damper slamming you may need a
http://en.wikipedia.org/wiki/Dashpot
Old 12-17-2009, 02:45 PM   #3
An old Tradesmen
Rewards Points: 8,202
Post pics of your unit.
Old 12-17-2009, 03:39 PM   #4
Fixer-'til-broker
Rewards Points: 262
This is a family environment. I don't think that would be appropriate...
Oh - the Dayton! Well, there's not much to see in such a tight closet. I looks like every other heater.
Incidentally, there are 2 ducts/vents leading to the roof that don't do anything but let in hot/cold air. I think they were for a previous unit. Can I block those off?
Old 12-17-2009, 03:42 PM   #5
An old Tradesmen
Don't know. Can't tell by the pics if it needs those pipes or not.
ooops, my mistake, you didn't post any pics of it.
Old 12-17-2009, 03:52 PM   #6
Check the alcohol content of your egg nog.
Old 12-18-2009, 09:23 AM   #7
Fixer-'til-broker
Rewards Points: 262
They are just 8x18" or so HVAC vents that go up to soffit vents on the roof. They are not connected to anything. My friend thought they were left open to vent the fumes out, but that doesn't really make sense.
No egg nog yet this year, and I don't drink. I see colors sometimes, and the voices tell me that's okay. The heater slam scares them, though.
Old 12-18-2009, 09:35 AM   #8
30 year tech
hvac122's Avatar
Those ducts in the attic could be combustion air and should not be shut. They provide air for the furnace to burn.
Pics of what you have would help.
hvac122 is offline   Reply With Quote
Old 12-18-2009, 11:04 AM   #9
Fixer-'til-broker
Rewards Points: 262
That doesn't make any sense either. Flat roof, single-story, no attic. The furnace is fan-fed from air vents underneath. The exhaust vents out the top, of course, through a stovepipe. This doubles as an a/c unit, and like I said these vents only let cold air in in the winter and hot air in the summer.
I'll take some pics when I get home...if my wife hasn't "hidden" the camera again.
Old 12-18-2009, 11:48 AM   #10
An old Tradesmen
Those are combustion air intake opening. They provide the air for the burner to operate.
The duct under your furnace are return air ducts for the house. That allow the air in the house to be heated or cooled and blown back into the house.
Old 12-18-2009, 01:04 PM   #11
Newbie Bill
Rewards Points: 522
Yes, you don't want the furnace sucking air out of your home to burn. That can excacerbate the voices and colors and potentially lead to flat line syndrome.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is online now   Reply With Quote
Old 12-20-2009, 08:48 PM   #12
Fixer-'til-broker
Rewards Points: 262
Still haven't found the darn camera and my cellphone won't take very good pictures of the closet. The burners are, in fact, fed by a fan that blows filtered air into the burners from underneath where the return vents are. The unit is pretty much sealed around where the ducts are, aside from little register holes in the cover. One of the ducts is just a hole for the a/c piping the exit through.
The unit is actually a Unitary Products Group model G2FD048S21A. Also known as Coleman, Eschelon, Trane, Dayton, York International...
I'll leave the vents alone, but how do I fix the slammer?
Old 12-20-2009, 10:26 PM   #13
An old Tradesmen
Thats an A/C coil model number, not a furnace model number.
The furnace model number is inside near the burner.
Old 12-22-2009, 09:32 AM   #14
Fixer-'til-broker
Rewards Points: 262
I guess I'll turn contortionist and take it all apart...
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 04:01 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
