#1 |
heater and a/c for garage
Is there such a unit I can install in my detached garage which I could use as air conditioner in the summer and heater in the winter?
#2 |
Electrician
Not sure where you could buy them but almost every motel room I have been has a unit like your describing.
| The Following User Says Thank You to darren For This Useful Post: | momof2labs (10-12-2012) |
#3 |
heater and a/c for garage |
#4 |
Super Moderator
I moved this to the heating and cooling section---
New members: Adding your location to your profile helps in many ways.--M-- |
#5 |
They make both heat pump versions and resistance heat only versions of this combo heat/AC unit.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded. |
| The Following User Says Thank You to AllanJ For This Useful Post: | momof2labs (10-12-2012) |
#6 |
Professional
ductless mini split heat pump or a ptac heat pump. They also make window units like this.
IT IS WHAT IT IS To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#7 |
#8 |
#9 |
You could use a mini split heat pump and make sure the garage is insulated real well. Straight electric heat in a garage is very expensive, been there already.
I aquired a fairly new 2 ton ICP gas pack that I installed on the roof for the garage and am happy with the results. I ran it mornings and evenings all last winter and our gas bill only jumped up 40 bucks. Do you have gas access to the garage? |
#10 | |
heater and a/c for garageQuote:
Thanks for the info. The detached garage is a shell, concrete floor and lots of extra plugs and extra electric panel. Yes, my first job will be to insulate. I'm just happy I will have a roof over my car. As a DIY'er, I would like a more comfortable area to work, etc. I plan to add a whole house generator with a buried propane tank so maybe I could somehow make use of heating with the propane. By the way, what is "ICP"? Thanks, again! |
#11 | |
| Tags |
a/c, garage, heater ![]() |
| Display Modes | |
