-   -   heater and a/c for garage (http://www.diychatroom.com/f17/heater-c-garage-159237/)
momof2labs 10-07-2012 07:39 AM
Is there such a unit I can install in my detached garage which I could use as air conditioner in the summer and heater in the winter?
darren 10-07-2012 07:53 AM
Not sure where you could buy them but almost every motel room I have been has a unit like your describing.
Dave632 10-07-2012 08:49 AM
It's called a heat pump.
oh'mike 10-07-2012 08:57 AM
I moved this to the heating and cooling section---
AllanJ 10-07-2012 09:29 AM
They make both heat pump versions and resistance heat only versions of this combo heat/AC unit.
hvactech126 10-07-2012 09:32 AM
ductless mini split heat pump or a ptac heat pump. They also make window units like this.
momof2labs 10-12-2012 06:14 AM
Excellent advice!
OH'Mike: Excellent advice ! Thanks v.m. (Stafford/Fredericksburg, VA)
momof2labs 10-12-2012 06:18 AM
Exc Advice!
Thanks. The house I'm buying in Fredericksburg, VA area has a heat pump (to my regret). So it looks like I only need to connect it. That's good news.
sammy37 10-12-2012 10:19 AM
You could use a mini split heat pump and make sure the garage is insulated real well. Straight electric heat in a garage is very expensive, been there already.
I aquired a fairly new 2 ton ICP gas pack that I installed on the roof for the garage and am happy with the results. I ran it mornings and evenings all last winter and our gas bill only jumped up 40 bucks.
Do you have gas access to the garage?
momof2labs 10-13-2012 08:56 AM
Hi Sammy:
Thanks for the info. The detached garage is a shell, concrete floor and lots of extra plugs and extra electric panel. Yes, my first job will be to insulate. I'm just happy I will have a roof over my car. As a DIY'er, I would like a more comfortable area to work, etc. I plan to add a whole house generator with a buried propane tank so maybe I could somehow make use of heating with the propane.
By the way, what is "ICP"?
Thanks, again!
sammy37 10-13-2012 11:09 AM
Originally Posted by momof2labs (Post 1029914)
Hi Sammy:
Thanks, again!
ICP is Iternational Comfort Products, they make Tempstar, Comfortmaker, Heil etc. They are tied in with Carrier.
