Heater Blowing Cold Air - HVAC - DIY Chatroom Home Improvement Forum
Old 11-19-2012, 09:17 PM   #1
Heater blowing cold air
Hey everyone,
Newbie here....first-time posting.
I have an American Standard Freedom 80 Single-stage furnace and when I fired it up today it blew cold air out. I checked the diagnostic reading and it comes back with two blinks followed by a pause and two more blinks. "External Lockout... Retries or Recycles exceeded"...does this mean the gas isn't catching the ignitor?
mikenlbc is offline   Reply With Quote
Old 11-19-2012, 10:21 PM   #2
Rewards Points: 614
well.... the ignitor usually never runs away so the gas does not have to catch it.... look inside... describe in more detail what you see... we will help you....
carmon is offline   Reply With Quote
Old 11-23-2012, 02:26 PM   #3
OK...finally had some time to do more investigating.
First things first...the model # is AUD080C948K1...it is an American standard Freedom 80 single stage furnace.
I opened everything up and when I turn it on, the blower starts just fine, but then I hear the click for gas and the gas flows for a few seconds and then I hear a click and the gas shuts off.
Old 11-23-2012, 02:32 PM   #4
Also should probably report that I don't see anything glowing like the ignitor on a clothes dryer. I see what I think is the ignitor...looks like a metal rod housed in a ceramic block. Appears to be buildup on the metal part, but not much.
AC blowing cold but not cooling the room DanStone HVAC 23 03-19-2012 09:59 AM
hot water pressure is 57% less than cold on new water heater wdgates Plumbing 6 03-06-2012 07:46 PM
Distance of water heater from incoming cold water main ncrango Plumbing 3 02-14-2012 12:15 PM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
Water Heater - Water reversed, hot is cold, cold is hot acaciaavenue Plumbing 5 12-09-2009 12:00 PM
