Heater Blower Won't Turn Off - HVAC - DIY Chatroom Home Improvement Forum
Old 07-25-2009, 11:53 PM   #1
heater blower won't turn off
I had the heat on a little while ago (why I was running it in the middle of summer is a much longer story). I turned the heat off several hours ago now but the blower is still running. I power cycled the unit at the breaker and the blower turned back on immediately, I also disconnected all the wires at the thermostat and toggled every setting on it I could thing of and the thing is still running.
Any advice? Time for a replacement? This heater is atleast 25 years old and probably needs to be replaced anyway.
lofar is offline   Reply With Quote
Old 07-26-2009, 09:18 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 396
What is the make, model and serial # of the unit?
Old 07-26-2009, 10:37 AM   #3
It is a Sun Dial brand the model is GH2M040H3.ON7C.
And I just realized this may be part of the class action against consolidated furnace if that is what you were getting at.
Old 07-26-2009, 10:54 AM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 396
No, but I have heard that the venting on some of those units has poisoned some people and they are unsafe to use. Probably your fan control or relay on the circuit board is stuck on. Time for a new furnace for safety reasons. Lots of rebates available to upgrade so the timing is good.
Old 07-26-2009, 03:07 PM   #5
Possible cause
You have several possible problems depending on the system construction. A temperature disk switch to cut the fan on when the heater has reached "warm'" is stuck in the on position. The heater controller is stuck in the "on' position. The fan relay has pitted and closed contacts. Someone has to look fer it.
jehiatt is offline   Reply With Quote
Old 07-26-2009, 03:23 PM   #6
Post a wiring diagram and we'll step you through the troubleshooting.
Old 07-26-2009, 04:57 PM   #7
The wiring diagram, or what used to be a wiring diagram, has faded to the point of being a single solid color blank label on the machine there are a few very very faint lines I can make out but that's it.
Old 07-27-2009, 02:19 PM   #8
Bad info on your heater at this site
http://www.seay-inspections.com/cons...%20heaters.htm
Problem with RUUD CH/A blower imabballer HVAC 2 01-09-2009 02:55 PM
blower won't turn on in AUTO nhpick02 HVAC 26 12-05-2008 07:27 PM
Turn Off Pilot Lighs: Heater & Stove (Flea Fogger) DanaWashburn HVAC 3 10-21-2008 08:16 PM
blower motor won't turn on blanker HVAC 7 10-03-2008 04:01 PM
