Heatcraft Eg-2 To Surelight 83m00 - HVAC - DIY Chatroom Home Improvement Forum
Old 09-15-2011, 04:02 PM   #1
Heatcraft eg-2 to Surelight 83m00
I am replacing my Heatcraft circuit board with a Lennox Surelight 83m00. The names of the connections don't match (even though HC is a Lennox company) could someone tell me which connectors from the HC to the Lennox connectors? Thanks.
Joe Austin is offline   Reply With Quote
Old 09-15-2011, 04:34 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
need more info....... Furnace model, old board model, is the surelight the direct replacement for your current board?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 09-15-2011, 04:47 PM   #3
heatcraft to surelight
Lennox Uhg80-40. I am not sure it is a direct replacement as I cannot find one for the Heatcraft. When I purchased the new board it was the replacement for the board that was supposed to be in the Uhg80.
Old 09-15-2011, 04:51 PM   #4
Old board model is Heatcraft eg-2
Old 09-15-2011, 04:59 PM   #5
AKA HVACTECHFW
I can't find a schematic......for old control. what connections do not match?
IT IS WHAT IT IS
Old 09-15-2011, 05:05 PM   #6
AKA HVACTECHFW
http://0190acd.netsolhost.com/manuals/83M00_Install.pdf
see tables 1 and 2..........
there are not that many connections to make so if you need more detail let us know.....Hopefully you have not disconnected old control yet.
IT IS WHAT IT IS
Old 09-15-2011, 05:11 PM   #7
attached
Old 09-15-2011, 05:22 PM   #8
AKA HVACTECHFW
Joe, did you look at the link i posted it tells you what goes where from the old to the new. BTW, no wonder I couldn't find it, you gave me the wrong board number.
IT IS WHAT IT IS
Old 09-15-2011, 05:47 PM   #9
I appreciate your help, but I have both of these documents. The labels on the Heatcraft are not the same labels as the Lennox. THAT is my original question. Or, asked another way; what are the corresponding labels, HC to Lennox and vice versa. Thanks.
Old 09-15-2011, 05:50 PM   #10
AKA HVACTECHFW
what labels? can you post some?
IT IS WHAT IT IS
Old 09-15-2011, 05:54 PM   #11
I'm Your Huckleberry
Rewards Points: 2,270
Take some clear pictures of both boards, post 'em and we'll be done with this very soon, I'd suspect.
Doc Holliday is offline   Reply With Quote
Old 09-15-2011, 07:17 PM   #12
83M00HC EGC2COOL120 ACHEATRTNPARK (2)CMB BL WRL1 120 VacEACHTG ACCLINE120 VAC TXXFMR120 VAC HotHUMACB CoolFANACB HeatNeutralNeutral24 Vac Hot120 vac120 Vac (5)24Vac RTNFlame SenseFSGround
Old 09-15-2011, 07:18 PM   #13
Let me try that again...
Old 09-15-2011, 07:20 PM   #14
AKA HVACTECHFW
those are posted in the tables as shown in the link I provided! (table 1 and table 2 (old vs. new))
IT IS WHAT IT IS
Old 09-15-2011, 07:43 PM   #15
correct. Heatcraft did not label their connectors/terminals with the same names as Lennox...can you translate the HC labels so they match the Lennox ones?
Tags
83m00 , circuit board , control board , heatcraft
