Heat Works In ONE Room! - HVAC - DIY Chatroom Home Improvement Forum
Old 12-13-2011, 09:10 AM   #1
Heat works in ONE room!
Hi guys, first timer here.
A few years ago my heat went out and it turned out to be the pilot light needing relit.
Two days ago I came home and the downstairs was freezing. I checked, and the heat was turned on, but the temp was at 56 degrees. I though, hmm, probably the pilot again. I walked upstairs and it was still cold UNTIL I walked into my very warm bedroom. The vents in there ONLY were pumping really well. My bedroom bathroom wasn't, and neither were any other vents in the house. I checked the basement and the pilot was running (seemed to be a slight burning smell in the bedroom). My filter had been in for only 3 weeks. Any idea of what's going on? Thanks!
whodatdare is offline   Reply With Quote
Old 12-13-2011, 10:24 AM   #2
If you have heat blowing in the bedroom then check all other supply and return registers and dampers. Sounds like they are closed.
fitter1 is offline   Reply With Quote
The Following User Says Thank You to fitter1 For This Useful Post:
whodatdare (12-13-2011)
Old 12-13-2011, 11:11 AM   #3
how
Rewards Points: 1,070
Are you saying that one room is getting heat actively blown in or that one room is getting hotter than normal air wafting in. My concern would be that the furnace blower is not actually working and what you are getting is a furnace that is chronically overheating. Is the hot room immediately above the furnace?
If you are not sure, do you have a summer fan switch you can try to see if the fan works.
Year, brand, model of furnace would help!
how is offline   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
Old 12-13-2011, 01:01 PM   #4
It's definitely being blown out. But only in our bedroom. there is about a 20 degree difference when leaving the bedroom. The furnace is in the basement, my bedroom is two floors up, but it is above the furnace. The garage and a bathroom are between the two. I'm not at home, so I can't see the yea/model/ etc.
Thanks!
Old 12-13-2011, 05:05 PM   #5
Okay,
just got home. It's a Trane XE90, installed in 2002.
Noticed that the error light is blinking 4 times. Checked the manual, and it's some type of High Limit code. Says to try cleaning/replacing filters. If that isn't it, check manual swithes. Then, if all else fails, replace the Main Limit Switch.
Is there more than one filter? I've recently replaced the one right next to the unit.
Old 12-13-2011, 06:02 PM   #6
Rewards Points: 734
Do you hear the blower running when it's on?
A blower not running, or running fast enough can trip the high limit.
AandPDan is offline   Reply With Quote
Old 12-14-2011, 10:04 AM   #7
YOU WERE EXACTLY RIGHT!!! Found that my capacitor is was bad. I'm changing it out today. Hopefully the blower is fine, because 20 bucks vs. 300 is pretty good!
THank you!!!!
Old 12-14-2011, 12:04 PM   #8
Rewards Points: 734
Good luck, thanks for the update.
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
Using server room heat as additional house heat Red Squirrel HVAC 6 10-11-2009 02:35 PM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 01:27 PM
Furnace room is warm, wasting heat Richo HVAC 13 02-18-2009 01:57 PM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 03:51 PM
